PLEASE HELP!, Car won't stay running and I'm out of ideas. |
messix |
Oct 11 2006, 08:47 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
chase all vacuum lines, i've had this happen to me a couple of times. knocked a hose loose.
RockinOldSchool |
Oct 11 2006, 09:41 PM
914 Junkie Group: Members Posts: 203 Joined: 2-August 06 From: Whatcom County, WA Member No.: 6,562 Region Association: Pacific Northwest |
Have you done the 'squirt in a bottle'. How's the battery holding up through all this? Haven't pulled an injector yet. Wanted to p/up a new injector seal set before I do that just to be safe. I'll grab a set tomorrow afternoon. And the battery's holding up fine. Hey John, Also check the battery cut off switch, they are known to go bad, although I have never heard of a case where you can get the motor to run for a few seconds and then cut out. What is the coil temp like? The battery cut off is fine, had a problem with it two weeks ago or so when I found that the ground in the engine bay was loose but that was a 2 second fix. Not sure about the coil temp, didn't think to check it. I'll do that first thing tomorrow. chase all vacuum lines, i've had this happen to me a couple of times. knocked a hose loose. Did once already, but it won't hurt me to double check. Oh, and all will be well with the girlfriend. If the car's not running tomorrow afternoon my pops is letting me take his truck for the weekend. |
RockinOldSchool |
Oct 12 2006, 02:18 AM
IT'S ALIVE!!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/aktion035.gif)
Well, Jim came over and lent me a hand fooling around with the car. Not sure what the cause was. But it now runs and we've found a slew of things that need to be done. The spark plug wires are in horrible shape with broken connectors. The rotor and cap could use to be replaced and one of the injector harness plugs was loose. Already took care of the harness plug. After I take care of the wires, cap and rotor I need to set my A/F ratio and check/set my fuel pressure and I should be fantastic. Thanks for all the ideas and help guys. Without your guidance I'd still be at square one trying to knock possibilities off of the list. (IMG:style_emoticons/default/smiley_notworthy.gif) (IMG:style_emoticons/default/pray.gif) |
messix |
Oct 12 2006, 08:47 AM
Lo-Fi Version | Time is now: 3rd June 2024 - 03:12 AM |
