Carpet in Arm Rest Pocket? |
AvalonFal |
Oct 8 2006, 07:44 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Noticed my '74 2.0L has a piece of carpet laid in the bottom of the driver's side arm rest pocket. The carpet doesn't match the floor carpet & was probably put in by a PO, so I'm wondering if carpet in the pocket was an original item.
tod914 |
Oct 8 2006, 03:23 PM
Should be like a grey piece of felt thats glued in there on the pocket side.
Pat Garvey |
Oct 8 2006, 08:36 PM
Noticed my '74 2.0L has a piece of carpet laid in the bottom of the driver's side arm rest pocket. The carpet doesn't match the floor carpet & was probably put in by a PO, so I'm wondering if carpet in the pocket was an original item. Nope! No carpet....just some very fine fuzzy stuff. In fact, with the tendancy for (even new) top seals to leak in a hard rain, I'd get it out of there quickly. |
914runnow |
Oct 9 2006, 10:16 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
Noticed my '74 2.0L has a piece of carpet laid in the bottom of the driver's side arm rest pocket. The carpet doesn't match the floor carpet & was probably put in by a PO, so I'm wondering if carpet in the pocket was an original item. Nope! No carpet....just some very fine fuzzy stuff. In fact, with the tendancy for (even new) top seals to leak in a hard rain, I'd get it out of there quickly. (IMG:style_emoticons/default/agree.gif) I have seen P/O's glue or place carpet in, and even foam.. Not original though..... WOULD like to see a pic though, if possible????? To see if the carpet piece was oem of sorts?? (IMG:style_emoticons/default/confused24.gif) |
AvalonFal |
Oct 10 2006, 03:17 PM
Not original though..... WOULD like to see a pic though, if possible????? To see if the carpet piece was oem of sorts?? (IMG:style_emoticons/default/confused24.gif) [/quote] No need for a pic. The piece I took out was definitely not original. It was black plush type carpet that matched the homemade carpet "floor mats" that the PO had over the normal carpet. |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:47 AM |
