Fog light wiring, I've read the other threads, but... |
jd66921 |
Oct 8 2006, 09:22 AM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
I seem to have a color issue with the wires.
I have found a black/blue wire, and brown wire, and another wire I cannot identify. It is gray/red. My wiring diagram shows a blue/black wire as the other color. Is that the same wire? Those three wires are not connected to anything, and have female spade lugs on them. Also, which is the fog light relay? I assume it is on the fuse panel, but Haynes shows a picture that doesn't resemble my fuse panel. The car is a 1975 1.8l L-Jet. Any help wouldbe appreciated! Jeff |
jd66921 |
Oct 8 2006, 11:21 AM
Never mind, I figured it out. The wiring diagram had a gray/red wire
on it that looked black/red. Circuit is working now, except I lost my low beams I'll trace that out next, and then get some fog/driving lights. Then I'll look at rewiring things to work the way I want them to work! It's never easy on this car.... Jeff |
PORobinSCHE |
Oct 8 2006, 06:54 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
jeff thanks for that post. i have to delve into the fog lamps also. now i know what wires to look for. the diagram i downloaded doesn't have good clarity on colors. best to you robin |
jd66921 |
Oct 8 2006, 07:57 PM
Lo-Fi Version | Time is now: 20th May 2024 - 10:29 PM |
