jd66921
Oct 8 2006, 09:22 AM
I seem to have a color issue with the wires.
I have found a black/blue wire, and brown wire, and another wire I cannot
identify. It is gray/red. My wiring diagram shows a blue/black wire as
the other color. Is that the same wire? Those three wires are not connected to anything, and have female spade lugs on them.
Also, which is the fog light relay? I assume it is on the fuse panel, but Haynes
shows a picture that doesn't resemble my fuse panel.
The car is a 1975 1.8l L-Jet.
Any help wouldbe appreciated!
Jeff
jd66921
Oct 8 2006, 11:21 AM
Never mind, I figured it out. The wiring diagram had a gray/red wire
on it that looked black/red. Circuit is working now, except I lost my low
beams I'll trace that out next, and then get some fog/driving lights.
Then I'll look at rewiring things to work the way I want them to work!
It's never easy on this car....
Jeff
PORobinSCHE
Oct 8 2006, 06:54 PM
jeff thanks for that post. i have to delve into the fog lamps also. now i know what wires to look for. the diagram i downloaded doesn't have good clarity on colors.
best to you
robin
jd66921
Oct 8 2006, 07:57 PM
QUOTE(PORobinSCHE @ Oct 8 2006, 05:54 PM)
best to you
robin
No problem!
Ask if you have any questions. I'll try to help.
Jeff
