Say a prayer for Fritz...., Diagnostic tomorrow on the motor... |
nine14cats |
Oct 11 2006, 02:58 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Keep positive thoughts for Fritz, our 911 track car. Tomorrow we run the diagnostic on the 3.6 993 motor to see why the sudden power loss at Thunderhill last month. The whole motor sounds like a giant air pump.
I'll update once we have some results back. Bill P. |
nine14cats |
Oct 11 2006, 03:04 PM
Symptoms.....
Running fine all day at the track. During the long straight at Thunderhill under full throttle the car suddenly loses power and cannot rev past 3500RPM. I coast around and pull into the pits. Car is running hot (240 deg)....oil pressure lower than usual...2.5 bar versus 4.5+...slight plume of white "something" coming from oil tank and breather. I drain some oil. No metal to be seen. We will take compression and leakdown, as well as cut open the oil filter. We will plug the ECU into the computer to read error codes. Some have said it's a computer shutdown for an error code. Others believe it's bent valves based on the cams shifting due to no keyway on this model of motor. Based on the above, offer up your opinions....We'll report back with what we find! Gotta have fun with a bad situation! Bill P. P.S. it's not really fun...but I'm trying not to be a pessimist. But I was in the car and my butt dyno says something mechanical.... (IMG:style_emoticons/default/blink.gif) |
Brad Roberts |
Oct 11 2006, 03:51 PM
I *might* be able to bring the Porsche System Tester II with me for the Boxster and the 993 engine.. if need be.
I can read the codes also. B |
Randal |
Oct 11 2006, 04:28 PM
Symptoms..... Running fine all day at the track. During the long straight at Thunderhill under full throttle the car suddenly loses power and cannot rev past 3500RPM. I coast around and pull into the pits. Car is running hot (240 deg)....oil pressure lower than usual...2.5 bar versus 4.5+...slight plume of white "something" coming from oil tank and breather. I drain some oil. No metal to be seen. We will take compression and leakdown, as well as cut open the oil filter. We will plug the ECU into the computer to read error codes. Some have said it's a computer shutdown for an error code. Others believe it's bent valves based on the cams shifting due to no keyway on this model of motor. Based on the above, offer up your opinions....We'll report back with what we find! Gotta have fun with a bad situation! Bill P. P.S. it's not really fun...but I'm trying not to be a pessimist. But I was in the car and my butt dyno says something mechanical.... (IMG:style_emoticons/default/blink.gif) Based upon no major metal noise I'm hoping the computer went into "limp" mode because of a sensor going haywire or something small like that. (IMG:style_emoticons/default/smile.gif) |
grantsfo |
Oct 11 2006, 04:40 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I'll say a prayer for Fritz if you say one for my 914-6. I blew something on my last runs at Infineon Friday.
Brad Roberts |
Oct 11 2006, 04:42 PM
It cuts back on the timing, but still runs fine in "limp" mode.
B |
nine14cats |
Oct 11 2006, 04:49 PM
nine14cats |
Oct 11 2006, 04:50 PM
Brad Roberts |
Oct 11 2006, 04:55 PM
You have to clear the codes with the PSTII. Same with the Boxster. They have "code readers" out there for cheap, but only the PSTII/III can clear them or ABS faults.
The PSTII/III is awesome. I can honk the horn with it.. LOL it does data logging on multiple channels also. I can drive the car and gather data to poor over looking for a fault. B |
Lo-Fi Version | Time is now: 4th May 2024 - 08:36 AM |
