CLEAN BEHIND THOSE ROCKER COVERS DAMMIT!, can YOU dodge the bullet? |
rhodyguy |
Oct 11 2006, 06:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
URY914 |
Oct 11 2006, 06:48 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,714 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Dude, stay off the CRACK!!!
MrKona |
Oct 11 2006, 07:23 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
That looks familiar... (IMG:style_emoticons/default/wink.gif)
Attached thumbnail(s) |
Loser_Cruiser |
Oct 11 2006, 07:45 PM
Member Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest |
Yeah I ve seen that too.
hmeeder |
Oct 11 2006, 07:51 PM
Dante's Sportscar Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 |
Shaved 5 pounds off the car
rhodyguy |
Oct 11 2006, 08:45 PM
missed me by that much...just surface. no holes. i batted .500 on those 6 pesky screws that hold the bottom of the rockers. other than that it's a piece o' cake. (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/smoke.gif)
k Attached image(s) |
GaroldShaffer |
Oct 11 2006, 08:47 PM
BTDT Lucky that this was all the damage I found, easy enough fix.
rjames |
Oct 11 2006, 11:27 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE BTDT Lucky that this was all the damage I found, easy enough fix. QUOTE Itsa914: I would poke the surface rust that's visible w/ a screw driver now that you've got part of the jack plate off. Mine looked like that too and it turned out that I had to cut into a bit of the longs as well. You'll at least want to get more of that lower part of whats left of the jack plate and maybe the sides as well where the plate sits flush against the long. Rust can form in there around the spot welds. That way you can get a wire wheel or sanding disk in there and completely get rid of the rust. Removing the part of the jack plate that sits flush against the long can be done without cutting into or damaging the long itself- it's not easy, but it can be done. Just my 2 cents from experience. (IMG:style_emoticons/default/beer.gif) |
sww914 |
Oct 11 2006, 11:50 PM
Spread a bunch of Rust-oleum around in there, it prevents rust according to the ads.
Hee Hee, this is a joke, don't do it. |
GaroldShaffer |
Oct 12 2006, 06:24 AM
QUOTE BTDT Lucky that this was all the damage I found, easy enough fix. QUOTE Itsa914: I would poke the surface rust that's visible w/ a screw driver now that you've got part of the jack plate off. Mine looked like that too and it turned out that I had to cut into a bit of the longs as well. You'll at least want to get more of that lower part of whats left of the jack plate and maybe the sides as well where the plate sits flush against the long. Rust can form in there around the spot welds. That way you can get a wire wheel or sanding disk in there and completely get rid of the rust. Removing the part of the jack plate that sits flush against the long can be done without cutting into or damaging the long itself- it's not easy, but it can be done. Just my 2 cents from experience. (IMG:style_emoticons/default/beer.gif) Yep I did all that, everything was cool (IMG:style_emoticons/default/clap56.gif) I'm not a welder, I had a friend do that for me. |
bd1308 |
Oct 12 2006, 10:37 AM
oh man thats gives me shudders
I have a plan to weld up my cars every few years, next time i'm going for VERY pretty. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:16 PM |
