Steel AA Flares + 9in Fuchs..., Do you need to roll fenders and will it fit? |
cobra94563 |
Oct 12 2006, 09:09 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Just got the flares on and I haven't convert the hubs to 5lug yet. But lining up the wheel, it looks like a tight fit. Do I need to roll the fenders (some or alot) before painting?
(IMG:style_emoticons/default/confused24.gif) |
propricer |
Oct 12 2006, 09:20 AM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Just got the flares on and I haven't convert the hubs to 5lug yet. But lining up the wheel, it looks like a tight fit. Do I need to roll the fenders (some or alot) before painting? (IMG:style_emoticons/default/confused24.gif) Running 9x15 rears on my FG flared V8 so it's at least do-able !!! |
cobra94563 |
Oct 12 2006, 09:38 AM
Did you roll the fender lip?
If I need to for sure, I rather do it before paint goes on. |
nomore9one4 |
Oct 12 2006, 09:46 AM
Member of the Eastcoast Thread Killers Club Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None |
I would roll it while you can . It all depends on how hard you corner and the actual diameter of your tire you use. I shaved the fiberglass on my flares and it was a good thing I did. (IMG:style_emoticons/default/smile.gif)
howell914 |
Oct 12 2006, 09:54 AM
Newbie Group: Members Posts: 39 Joined: 25-January 06 From: ct. Member No.: 5,472 |
I rolled mine before painting, why not, got 17/9's on order from ccw, i'll let ya know how it works out.
ClayPerrine |
Oct 12 2006, 12:03 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have 16x9s on the rear of my car and they fit just fine...... No clearance problems at all.
So.Cal.914 |
Oct 12 2006, 12:17 PM
The AA flairs are designed with 7's and 9's in mine, that said check with a
tape measure and a straight edge. Measure from mateing edge(where the hub/ rotor meets the wheel) to the outer lip of the wheel, than from the hub/rotor to a straight edge laid across the outside of the wheel opening of the flair. subtract the lip measurement and compare. |
McMark |
Oct 12 2006, 12:40 PM
What lip are you rolling? 9s will fit, depending on what your backspacing is and if the flares are installed correctly. Most people get flares right and I'm sure you will too, but it is a conceivable problem. (IMG:style_emoticons/default/wink.gif) |
cobra94563 |
Oct 12 2006, 01:41 PM
(IMG:style_emoticons/default/confused24.gif) What lip are you rolling? 9s will fit, depending on what your backspacing is and if the flares are installed correctly. Most people get flares right and I'm sure you will too, but it is a conceivable problem. (IMG:style_emoticons/default/wink.gif) The fender edge that folds straight in - towards the center of the car. It's about 1/2 - 3/4 inch. If there is contact, it would be sidewall and that edge. I could bend it up for more clearance - no experience on how difficult that is. The guage of the AA flares seems thicker then the OEM guage. ClayPerrine - did you have to roll the edge? (IMG:style_emoticons/default/smash.gif) |
Aaron Cox |
Oct 12 2006, 02:30 PM
clay - where did you get 16x9's? they are like 2000 a pair LOL
nice score.... BTW - 9's should be an easy fit... 10's are the fun ones to fit... LOL |
ClayPerrine |
Oct 12 2006, 02:56 PM
clay - where did you get 16x9's? they are like 2000 a pair LOL nice score.... BTW - 9's should be an easy fit... 10's are the fun ones to fit... LOL Ebay... They are 951 wheels... The guy who sold them took them off the 944 turbo 3 months after buying it to put on OZ wheels. They sat in his attic for years, undisturbed. He found them 2 years after he sold the car, and put them up on Ebay. All of them were straight and true, and they came with the original center caps. They were not cheap, but they were worth it. And NO, I didn't pay 2000.000 for the set of 4. |
Aaron Cox |
Oct 12 2006, 03:21 PM
uhmm.. i think 951's had 951 8's and 951 7's... no 9's
QUOTE 7 x 16 23.3mm 138mm 951.362.115.00(944) 8 x 16 10.6mm 112mm 911.362.117.00 8 x 16 23.3mm 125mm 951.362.117.00(944) 9 x 16 15mm 130mm 911.362.118.00 |
seanery |
Oct 12 2006, 04:23 PM
(IMG:style_emoticons/default/agree.gif) 86 951?
I had one - 7s & 8s uhmm.. i think 951's had 951 8's and 951 7's... no 9's QUOTE 7 x 16 23.3mm 138mm 951.362.115.00(944) 8 x 16 10.6mm 112mm 911.362.117.00 8 x 16 23.3mm 125mm 951.362.117.00(944) 9 x 16 15mm 130mm 911.362.118.00 |
Aaron Cox |
Oct 12 2006, 04:27 PM
clay,
you lose buckwheat (IMG:style_emoticons/default/smile.gif) no more use of the "aaron retard" pic for you being wrong on this one (IMG:style_emoticons/default/smile.gif) |
914-8 |
Oct 12 2006, 04:42 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Yeah, there is only one version/offset of the Fuchs 16x9.
ClayPerrine |
Oct 13 2006, 11:40 AM
clay, you lose buckwheat (IMG:style_emoticons/default/smile.gif) no more use of the "aaron retard" pic for you being wrong on this one (IMG:style_emoticons/default/smile.gif) That will NEVER happen.. I have the picture.. and I am NOT afraid to use it.... |
Aaron Cox |
Oct 13 2006, 11:41 AM
you were wrong...im right (IMG:style_emoticons/default/smile.gif)
and you are gonna be wrong on the 944 calipers LOL |
don9146 |
Oct 13 2006, 01:53 PM
Member Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None |
I have Fuch 16 x 7 fronts and 16 x 9 rears on my 914 with factory flares (I don't know if there is a difference between the factory and AA flares) with 225/50 front tires and 245/45 tires in the back. The 16 x 9 rear Fuches came on either a 911 with the optional "turbo-look" package (and some of those had 16 x 8 rears, just to make things more complicated) and 911 Turbos. I'm nit-picking a bit differentiating between a 911 and a 911 turbo, but the wheels have diffetent part nubmers stamped on them.
If you want to see some pics of the car with the big wheels and tires (in case you want visual proof), I have a few posted at http://www.sawyersmotorsports.com/914page.html . Later, Don |
cobra94563 |
Oct 13 2006, 02:07 PM
Don,
Nice! Did you have to roll your rear fender lips? BTW, what color (orange or red) is that? |
siverson |
Oct 13 2006, 02:48 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I also have 16x9s in the rear and with a 1/4" spacer (to clear C2T rear calipers). The fit fine, but I would -highly- recommend fitting the suspension and wheels before mounting the flares. That way you can just push & pull the factory fenders so it all fits correctly.
-Steve |
Lo-Fi Version | Time is now: 20th May 2024 - 05:12 PM |
