Weber 36IDF's, Too small for a 2.0 ? |
bribar |
Oct 12 2006, 11:15 AM
Newbie Group: Members Posts: 17 Joined: 31-July 06 From: Chicago Member No.: 6,542 |
I have a 73 2.0 (new to me). I just removed the dual webers and found that they are marked as 36IDF made in Bologna, Italy. I didn't even know 36's existed.
I thought 40-or 44's were the ticket. The PO was a doctor that had the car serviced for everything. He didn't know what a wrench was. Are these to small for the 2.0 with a 3/4 cam? Any suggestions on jetting? Thanks, Brian |
Aaron Cox |
Oct 12 2006, 11:17 AM
pretty rare...
they work BITCHIN on a 1.7 ... ive seen a pair of em on a ghia before.... 40's or 44's for a hot 2L.... |
So.Cal.914 |
Oct 12 2006, 11:31 AM
Aarons right, 40's or 44's are the hot ticket but the 36's will work fine and save
you at the pump. You will not get the performance of a larger carb but unless you race it I would not worry about it and run them. |
bribar |
Oct 12 2006, 12:59 PM
Aarons right, 40's or 44's are the hot ticket but the 36's will work fine and save you at the pump. You will not get the performance of a larger carb but unless you race it I would not worry about it and run them. Emulsion Tubes are F7 Mains are 115 Idle jets are 55 |
Mueller |
Oct 12 2006, 01:40 PM
I have a 73 2.0 (new to me). I just removed the dual webers and found that they are marked as 36IDF made in Bologna, Italy. I didn't even know 36's existed. I thought 40-or 44's were the ticket. The PO was a doctor that had the car serviced for everything. He didn't know what a wrench was. Are these to small for the 2.0 with a 3/4 cam? do you have specs on the cam? 3/4 is kinda generic (old skool) for non-stock cam... Any suggestions on jetting? Thanks, Brian |
Lo-Fi Version | Time is now: 21st May 2024 - 02:58 AM |
