who can tell about this front swaybar?, dif than the one in the 73' |
rhodyguy |
Oct 12 2006, 01:41 PM
asdf
Ferg |
Oct 12 2006, 01:47 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
dunno but can't wait to hear, it's the same one I got in my 74.
Ferg (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Oct 12 2006, 01:49 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Could be a "H & H" adjustible. Popular in the '70's.
Ferg |
Oct 12 2006, 01:52 PM
Are the triangular plates in the wheel well different too. Mine are, and the bushings are hard plastic cylindrical shape, not tapered rubber like oem replacements.
Ferg |
rhodyguy |
Oct 12 2006, 02:09 PM
look familiar mike? i don't know about the bushings. old school, too cool. (IMG:style_emoticons/default/thumb3d.gif)
k Attached image(s) |
Heeltoe914 |
Oct 12 2006, 02:10 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Its better than stock you get some adj, Consider it and upgrade.
Check the size of the bar it mite be bigger than stock. |
Aaron Cox |
Oct 12 2006, 02:35 PM
H and H bar... should be 19mm.....
rhodyguy |
Oct 12 2006, 02:39 PM
i'm not pulling it. i just wanted a few details regarding it.
k |
iamchappy |
Oct 12 2006, 02:47 PM
It's a H&H, I had one in my 73.
Heeltoe914 |
Oct 12 2006, 03:02 PM
If you are going to keep it enjoy it, its a good bar. But looking at all that road dirt around it and on it think about removing the brackets and lubing up the solid buchings I think are in there.
Ferg |
Oct 12 2006, 03:08 PM
Yep, that's what I have as well! Mine's out of the car, and bushings are pretty worn. Is there still are source for them? Or heavy lube and reuse?
Ferg |
Series9 |
Oct 12 2006, 04:36 PM
Yep, I got to see this stuff first-hand on Monday at Ferg's.
He said Pelican(?) sent him the wrong front SB bushings. When he showed me the bushings they sent, I said 'those are correct'. He said 'well they look nothing like these' and I said 'those are definitely not stock'. Interesting. |
rhodyguy |
Oct 12 2006, 04:47 PM
honest mistake on both ends. mystery solved. i bet someone at paragon can help you now that you know what type of bar you have.
k |
jones |
Oct 12 2006, 04:50 PM
Member Group: Members Posts: 126 Joined: 4-March 04 From: Seattle Member No.: 1,751 |
Very cool!
tommy914 |
Oct 12 2006, 05:23 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
a bit of technical data on your sway bar.
Attached thumbnail(s) |
Howard |
Oct 12 2006, 05:34 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
It's the one I have in Suzi. Now I know it's an H&H (IMG:style_emoticons/default/biggrin.gif)
Thanks for the info. |
jones |
Oct 12 2006, 05:47 PM
Cool chart tommy914. Do you have one? If so what do you think? Bushings still available? What's the scoop???
Series9 |
Oct 12 2006, 05:48 PM
That's not the one Ferg has. His bushing is cylindrical and doesn't have the 'U' shape bracket to secure it.
Hmmm. |
Series9 |
Oct 12 2006, 05:51 PM
This is what Ferg has. It's different from the drawing for the H&H.
Howard |
Oct 12 2006, 06:18 PM
Here's mine. Is it is or is it ain't?
Lo-Fi Version | Time is now: 17th May 2024 - 08:57 AM |
