rhodyguy
Oct 12 2006, 01:41 PM
asdf
Ferg
Oct 12 2006, 01:47 PM
dunno but can't wait to hear, it's the same one I got in my 74.
Ferg
URY914
Oct 12 2006, 01:49 PM
Could be a "H & H" adjustible. Popular in the '70's.
Ferg
Oct 12 2006, 01:52 PM
Are the triangular plates in the wheel well different too. Mine are, and the bushings are hard plastic cylindrical shape, not tapered rubber like oem replacements.
Ferg
rhodyguy
Oct 12 2006, 02:09 PM
look familiar mike? i don't know about the bushings. old school, too cool.
k
Heeltoe914
Oct 12 2006, 02:10 PM
Its better than stock you get some adj, Consider it and upgrade.
Check the size of the bar it mite be bigger than stock.
Aaron Cox
Oct 12 2006, 02:35 PM
H and H bar... should be 19mm.....
rhodyguy
Oct 12 2006, 02:39 PM
i'm not pulling it. i just wanted a few details regarding it.
k
iamchappy
Oct 12 2006, 02:47 PM
It's a H&H, I had one in my 73.
Heeltoe914
Oct 12 2006, 03:02 PM
If you are going to keep it enjoy it, its a good bar. But looking at all that road dirt around it and on it think about removing the brackets and lubing up the solid buchings I think are in there.
Ferg
Oct 12 2006, 03:08 PM
Yep, that's what I have as well! Mine's out of the car, and bushings are pretty worn. Is there still are source for them? Or heavy lube and reuse?
Ferg
Series9
Oct 12 2006, 04:36 PM
Yep, I got to see this stuff first-hand on Monday at Ferg's.
He said Pelican(?) sent him the wrong front SB bushings. When he showed me the bushings they sent, I said 'those are correct'.
He said 'well they look nothing like these' and I said 'those are definitely not stock'.
Interesting.
rhodyguy
Oct 12 2006, 04:47 PM
honest mistake on both ends. mystery solved. i bet someone at paragon can help you now that you know what type of bar you have.
k
jones
Oct 12 2006, 04:50 PM
Very cool!
tommy914
Oct 12 2006, 05:23 PM
a bit of technical data on your sway bar.
Howard
Oct 12 2006, 05:34 PM
It's the one I have in Suzi. Now I know it's an H&H
Thanks for the info.
jones
Oct 12 2006, 05:47 PM
Cool chart tommy914. Do you have one? If so what do you think? Bushings still available? What's the scoop???
Series9
Oct 12 2006, 05:48 PM
That's not the one Ferg has. His bushing is cylindrical and doesn't have the 'U' shape bracket to secure it.
Hmmm.
Series9
Oct 12 2006, 05:51 PM
This is what Ferg has. It's different from the drawing for the H&H.
Howard
Oct 12 2006, 06:18 PM
Here's mine. Is it is or is it ain't?
Series9
Oct 12 2006, 07:07 PM
Howard, that's the factory bushing and cap.
sixnotfour
Oct 12 2006, 07:12 PM
H&H had two designs the second deisgn like factory cap ,It is flat plate triangle wth pipe welded to it.(like Rohdyguys)
Horward has H&H arms maybe bar too, factory cap as Joe said.
TimT
Oct 12 2006, 07:54 PM
werd up
I have a H&H on my 911 that I purchased almost 20 years ago. I also have the documentation. I wore the bushings out years ago, and just made some replacements out of delrin. A few minutes on the lathe was all it took
The alternate H&H mount was to convert cars from under-body to through-body swaybars. The tubs had the stamping where the bar passed through, even though the cars had underbody bars.
914werke
Oct 12 2006, 09:00 PM
Series9
Oct 12 2006, 09:10 PM
QUOTE(rdauenhauer @ Oct 12 2006, 09:00 PM)
That's what Ferg has.
tommy914
Oct 12 2006, 09:26 PM
QUOTE(jones @ Oct 12 2006, 06:47 PM)
Yes, still have one attached. I like it, but I would never run it as stiff as the one shown in the first picture. I haven't needed replacement bushings yet. I also replaced the droplinks with weltmeister adjustable.
