looking for a picture, need to remove ign. tumbler |
toon1 |
Oct 12 2006, 08:26 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Iv'e searched the archives. where is the location that needs to be drilled to get the tumbler out of the housing??
dlo914 |
Oct 12 2006, 08:43 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
i dont recall the need to drill out the tumbler. when i removed the tumbler i first removed the steering wheel, and then proceeded to remove the necessary screws and the tumbler slid right out.
URY914 |
Oct 12 2006, 08:58 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,605 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
i dont recall the need to drill out the tumbler. when i removed the tumbler i first removed the steering wheel, and then proceeded to remove the necessary screws and the tumbler slid right out. (IMG:style_emoticons/default/agree.gif) no need to drill anything. |
914Sixer |
Oct 12 2006, 09:25 PM
The 75-76 tumbler with the key requires you drill hole to release it. The lock assembly comes right out like the 72-on. The factory manual has the dimensions. If you need a copy email me at a914nut@email.com with your address.
toon1 |
Oct 12 2006, 09:32 PM
I have the switch assembly out of the colum. I am trying to get the lock part out of the body. Looking thorough the archives there is reference to driiling a hole in the switch body to remove the key tumbler portion.
Is there a source for new key switches, pelican has them a NLA. |
toon1 |
Oct 13 2006, 10:48 AM
I was able to get the key assembly apart.
Is there any interest on a pictorial on dissasembly, cleaning and reassembly of the key portion of the ignition switch?? |
Lo-Fi Version | Time is now: 16th May 2024 - 06:32 PM |
