where is the temp sensor for temp gauge exactly? |
dhopkins |
Oct 14 2006, 02:10 PM
Member Group: Members Posts: 50 Joined: 7-July 04 From: Rydal, Pa Member No.: 2,315 |
I am trying to get the temp gauge to work. Where exactly is the sensor located? Is it right behind the distributor? Thanks in advance.
Don |
Mueller |
Oct 14 2006, 02:12 PM
oil temp is under the motor if your motor has one....
oil pressure is next to the distributor |
rhodyguy |
Oct 14 2006, 02:28 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
oem/stock temp sendor is located on the bottom, dr side front of the engine (see picture). the wire runs up behind the fan shroud. it's secured with a little metal tab, again behind the fan shroud.
k Attached image(s) |
Bleyseng |
Oct 14 2006, 04:10 PM
has this special plate to fit the sender in.
(IMG:http://i8.photobucket.com/albums/a9/bleyseng/taco.jpg) |
rhodyguy |
Oct 14 2006, 04:35 PM
look for this.
dhopkins |
Oct 14 2006, 04:36 PM
Can't find it. Look at attached pic and tell me where it is.
don from philly Attached thumbnail(s) |
rhodyguy |
Oct 14 2006, 04:37 PM
and you may find one of these.
dhopkins |
another pic
dhopkins |
Oct 14 2006, 04:38 PM
another
Bleyseng |
Oct 14 2006, 04:39 PM
you don't have one so I would source one in the classifieds or Jake Raby has a few.
rhodyguy |
Oct 14 2006, 04:48 PM
it's the big round thing next to the bar in post #6. you're missing the cover plate i pictured in post #5. plus i can't see the wire section. there may still be pictures of the whole package in the classifieds from when i sold one.
k |
Bleyseng |
Oct 14 2006, 05:21 PM
red circled plate is a non temp sender plate
dhopkins |
Oct 14 2006, 05:32 PM
But my car has a gauge and 3 wires running to it? HOW CAN THIS BE/
DON |
Bleyseng |
Oct 14 2006, 05:45 PM
and the gauge works right? Could be its mounted somewhere else, like a dipstick sensor..
look for it! if its doesn't work this is why, no sender. (IMG:style_emoticons/default/confused24.gif) |
Mueller |
Oct 15 2006, 12:22 AM
But my car has a gauge and 3 wires running to it? HOW CAN THIS BE/ DON has someone possibly owned the car before you??? (IMG:style_emoticons/default/biggrin.gif) good chance you have the sender, just no wire going to it........motor might have been replaced (almost certain it's been removed at least once) |
BarberDave |
Oct 15 2006, 03:45 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
What you need is on E-bay right now. ( not my add) # 130037129185 you will still need O-rings,and metal gaskets,for the bolts,and the bolts,or you will have one hell of a oil leak. Good luck! Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 07:45 PM |
