dhopkins
Oct 14 2006, 02:10 PM
I am trying to get the temp gauge to work. Where exactly is the sensor located? Is it right behind the distributor? Thanks in advance.
Don
Mueller
Oct 14 2006, 02:12 PM
oil temp is under the motor if your motor has one....
oil pressure is next to the distributor
rhodyguy
Oct 14 2006, 02:28 PM
oem/stock temp sendor is located on the bottom, dr side front of the engine (see picture). the wire runs up behind the fan shroud. it's secured with a little metal tab, again behind the fan shroud.
k
Bleyseng
Oct 14 2006, 04:10 PM
has this special plate to fit the sender in.
rhodyguy
Oct 14 2006, 04:35 PM
look for this.
dhopkins
Oct 14 2006, 04:36 PM
Can't find it. Look at attached pic and tell me where it is.
don from philly
rhodyguy
Oct 14 2006, 04:37 PM
and you may find one of these.
k
dhopkins
another pic
dhopkins
Oct 14 2006, 04:38 PM
another
Bleyseng
Oct 14 2006, 04:39 PM
you don't have one so I would source one in the classifieds or Jake Raby has a few.
rhodyguy
Oct 14 2006, 04:48 PM
it's the big round thing next to the bar in post #6. you're missing the cover plate i pictured in post #5. plus i can't see the wire section. there may still be pictures of the whole package in the classifieds from when i sold one.
k
Bleyseng
Oct 14 2006, 05:21 PM
red circled plate is a non temp sender plate
dhopkins
Oct 14 2006, 05:32 PM
But my car has a gauge and 3 wires running to it? HOW CAN THIS BE/
DON
Bleyseng
Oct 14 2006, 05:45 PM
and the gauge works right? Could be its mounted somewhere else, like a dipstick sensor..
look for it!
if its doesn't work this is why, no sender.
Mueller
Oct 15 2006, 12:22 AM
QUOTE(dhopkins @ Oct 14 2006, 04:32 PM)
DON
has someone possibly owned the car before you???
good chance you have the sender, just no wire going to it........motor might have been replaced (almost certain it's been removed at least once)
BarberDave
Oct 15 2006, 03:45 AM
What you need is on E-bay right now. ( not my add) # 130037129185 you will still need O-rings,and metal gaskets,for the bolts,and the bolts,or you will have one hell of a oil leak. Good luck! Dave
