Engine Stand Adapter Ring, Sketch Adapter ring |
porsche914dl |
Oct 14 2006, 03:17 PM
Member Group: Members Posts: 69 Joined: 24-August 04 From: BC, Canada Member No.: 2,608 |
HI, friends,
Does anyone got a sketch with size & details about the adapter ring to use for mounting the engiune to an ordinary engine stand so that I can make one. THanks. POrsche914dl |
Mueller |
Oct 14 2006, 03:45 PM
HI, friends, Does anyone got a sketch with size & details about the adapter ring to use for mounting the engiune to an ordinary engine stand so that I can make one. THanks. POrsche914dl if you have an engine or transmission in front of you, you have the dims you need... |
John |
Oct 14 2006, 10:29 PM
I drew one in AutoCAD.
Attached File(s) 06191401.pdf ( 76.51k ) Number of downloads: 149 |
porsche914dl |
Oct 15 2006, 01:30 AM
Hi, there,
thanks for all the input. Hi, Mueller: I think I need the ring before I dismounted the engine. Thanks anyway. HI, Johnman: Thanks. Got it. Will draw it out to see. Thanks alot. Porsche914dl |
Mueller |
Oct 15 2006, 09:05 AM
Hi, there, thanks for all the input. Hi, Mueller: I think I need the ring before I dismounted the engine. Thanks anyway. I figured you suffered the same sickness as most and had at least an extra motor and transmission laying around (IMG:style_emoticons/default/smile.gif) HI, Johnman: Thanks. Got it. Will draw it out to see. Thanks alot. Porsche914dl |
John |
Oct 15 2006, 07:58 PM
If you make some, or have it made, I would like one. I know there is someone out there that has them made in China and regularly sells them on e-bay for fairly cheap. Right now their name escapes me.
Note: My drawing was made to be able to WELD the ring to something. If you want to BOLT this ring to a standard type 4-arm engine stand, you will need to drill and tap some holes in it. I found it cost prohibitive to have a machine shop make these so the project ended right there. These rings can be had for less than $150.00 The first "ring" I ever had made was made by one of my friend's dad for free. He was a great old school machinist and a great guy. I miss him. |
dflesburg |
Oct 15 2006, 08:05 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
I tried to have two made last summer, turned out it was cheaper to just buy them from
http://www.mainelycustombydesign.com/ you can get just the ring or get the whole thing there... |
Joe Bob |
Oct 15 2006, 08:12 PM
GeorgeRud |
Oct 15 2006, 09:47 PM
I've been using one of their adapter rings for the last year of so and it's a very nicely made piece. Unfortunately, you can't get to the flywheel, clutch, and pressure plate with the adapter alone (at least with my old engine stand). If I did it again, I'd spring the extra and get the one with the attached arms and engine stand adapter, not just the ring.
PRS914-6 |
Oct 16 2006, 09:26 AM
If you are going to split the cases, you obviously need the ring. If not, you can use the standard engine stand without any problems at all. You just need 4 spacers easily made at home to clear around the flange on the case where the tranny goes. If needed, I'll post a picture.
anthony |
Oct 16 2006, 10:03 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
I bought this adaptor on ebay. Seems plenty beefy for a type IV engine:
(IMG:http://i15.ebayimg.com/02/i/05/0f/f6/6c_1.JPG) You can also find the ring adaptor on ebay for $150. |
jd74914 |
Oct 16 2006, 10:07 AM
You never really need the ring (IMG:style_emoticons/default/laugh.gif)
I rebuilt my engine without a stand and it all worked out well. I just built a little table for the engine to sit on that I didn't mind dirtying |
Lo-Fi Version | Time is now: 20th May 2024 - 10:13 PM |
