Help diagnose this noise?, Sounds like something's rubbing on wheels |
FB914 |
Oct 16 2006, 03:26 PM
74 alaska blue 2.0 Group: Members Posts: 63 Joined: 1-March 05 From: Philly Member No.: 3,689 |
I have a sound like something is rubbing on the right rear tire at speed. It is not related to the engine - it changes with the speed of the car, not the RPM's. At 40 MPH you can hear it pretty good and the pitch gets higher as the speed increases. The tires are OK - no metal showing thru the rubber. There is nothing I can see that would be rubbing on the wheel or tire or the ground. Any ideas? Thanks in advance for your help
Frank B |
904svo |
Oct 16 2006, 03:37 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I have a sound like something is rubbing on the right rear tire at speed. It is not related to the engine - it changes with the speed of the car, not the RPM's. At 40 MPH you can hear it pretty good and the pitch gets higher as the speed increases. The tires are OK - no metal showing thru the rubber. There is nothing I can see that would be rubbing on the wheel or tire or the ground. Any ideas? Thanks in advance for your help Frank B Check your rear bearings they may be bad. |
914nerd |
Oct 16 2006, 03:39 PM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
Yep, check the rear bearings (might as well check all of them while you are at it) and you may need to repack them or possibly buy a new bearing set
Charles |
FB914 |
Oct 16 2006, 04:35 PM
I have a sound like something is rubbing on the right rear tire at speed. It is not related to the engine - it changes with the speed of the car, not the RPM's. At 40 MPH you can hear it pretty good and the pitch gets higher as the speed increases. The tires are OK - no metal showing thru the rubber. There is nothing I can see that would be rubbing on the wheel or tire or the ground. Any ideas? Thanks in advance for your help Frank B Check your rear bearings they may be bad. Thanks, that was what I thought. |
orange914 |
Oct 16 2006, 04:42 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
probably a wheel bearing... but from personal experience, it might be from a water bottle stuck in between the caliper and rim. it was caused by someone in the family putting it in moms '05 taurus wagon and forgetting about it...lol (IMG:style_emoticons/default/chairfall.gif) (IMG:style_emoticons/default/chair.gif) (happened a week ago)
SGB |
Oct 17 2006, 07:43 AM
the easiest "check" is to see if the wheel (and lug bolts) get excessively hot....
Lo-Fi Version | Time is now: 20th May 2024 - 06:59 PM |
