Cutting the dashboard face, Gauge install |
TINCAN914 |
Oct 17 2006, 06:25 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
I want to install my CHT gauge on the dash face of my car, (saw this at RRC) looked real clean. My thought was to cut a larger dia hole where the lighter is. I'm not sure the best way to go about doing this. What's the best way to cut it? Anyone know if I need to remove the entire dash, just the kneepad? advice anyone???
Brew |
Oct 17 2006, 06:30 AM
That's Captain Moron to you! Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 |
I got the hole saw!!!! (IMG:style_emoticons/default/sawzall-smiley.gif)
bd1308 |
Oct 17 2006, 06:34 AM
Unplug the battery, and i'd just drill through the material
TINCAN914 |
Oct 17 2006, 06:45 AM
Want to come over and help me out? Beer's on me..... (IMG:style_emoticons/default/drunk.gif) My fear is what's behind the dash and the probability that I will sever everything once I begin cutting.... (IMG:style_emoticons/default/headbang.gif) |
TINCAN914 |
Oct 17 2006, 06:54 AM
Unplug the battery, and i'd just drill through the material Britt, I have a hole saw perfect size. The problem is since the lighter hole is already on existance, there is nothing for the drill bit to bite into to pull the teeth into the metal and the teeth on the drill teeth just slide... (IMG:style_emoticons/default/sad.gif) |
Brew |
Oct 17 2006, 07:03 AM
I'll be there ~ 4:20pm, if that's cool with you. (IMG:style_emoticons/default/beerchug.gif)
If you want it where the lighter is, maybe just move the new hole off center enough to miss the lighter hole with the pilot bit, but still engulf it? We'll figure something out. (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) |
TINCAN914 |
Oct 17 2006, 07:05 AM
I'll be there ~ 3:20pm, if that's cool with you. (IMG:style_emoticons/default/beerchug.gif) If you want it where the lighter is, maybe just move the new hole off center enough to miss the lighter hole with the pilot bit, but still engulf it? We'll figure something out. (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) That's cool with me.... Thanks man-Dingo... |
Brew |
Oct 17 2006, 07:08 AM
Note edit on time change, Bri. I have to run to the folks house and deliver a tailgate for Pops truck.
TINCAN914 |
Oct 17 2006, 07:45 AM
blitZ |
Oct 17 2006, 07:49 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
bd1308 |
Oct 17 2006, 07:52 AM
wait a sec, cant you find one of those cone shaped bits to drill holes with? They step from a very small size to a very LARGE size, and drill concentric with the cig lighter hole. Dunno if thats what you want, but seems like you'd want it centered with something.
Aaron Cox |
Oct 17 2006, 08:43 AM
wait a sec, cant you find one of those cone shaped bits to drill holes with? They step from a very small size to a very LARGE size, and drill concentric with the cig lighter hole. Dunno if thats what you want, but seems like you'd want it centered with something. that would be one LARGE and expensive Unibit... but a good idea |
G e o r g e |
Oct 17 2006, 08:56 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
if drilling off center doesn't allow a descent guide hole location, take some scrap sheet metal and a couple of self taping screws and fill in the lighter hole then drill. place the screws just outside of the lighter hole. also i would cut the vinyl as a hole saw will pull the living sheet out of it. (IMG:style_emoticons/default/beerchug.gif)
majkos |
Oct 17 2006, 09:21 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
if drilling off center doesn't allow a descent guide hole location, take some scrap sheet metal and a couple of self taping screws and fill in the lighter hole then drill. place the screws just outside of the lighter hole. also i would cut the vinyl as a hole saw will pull the living sheet out of it. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) |
Bartlett 914 |
Oct 17 2006, 09:28 AM
How big of a hole are you talking about? Electricial knockout punch will give the best hole. Far better than you would get by using a hole saw and you don't need to worry about a backing plate. I have some larger ones I can loan. I also agree about cutting the vinyl first.
pfierb |
Oct 17 2006, 09:41 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
wait a sec, cant you find one of those cone shaped bits to drill holes with? They step from a very small size to a very LARGE size, and drill concentric with the cig lighter hole. Dunno if thats what you want, but seems like you'd want it centered with something. I use them all the time in my work and the results are great and they are easy to use but Aaron is right they can be very expensive to use only one time. |
Bartlett 914 |
Oct 17 2006, 09:42 AM
Just a reminder. There is the vinyl. This is adhered to a thin sheet metal strip. The dash is behind this. Where the switches are located, there is a raised section. This means that the strip of sheet metal with the vinyl contacts the dash at these points. There is some foam adhesive strips elsewhere. I would remove it all to make sure you get the best installation. That is a lot more work but less guessing.
Brew |
Oct 17 2006, 12:36 PM
Mark,
A Greenlee should punch thru all of it in one shot, no? Maybe not the vinyl, but all else? |
TINCAN914 |
Oct 17 2006, 12:48 PM
I removed the kneepad, and cross cut the vinyl (will be replaced anyway) in short order. cut a small piece of sheetmetal and used two sheet metal screws for a guide on the hole saw (couldn't cut butter). So I used a drill bit went around the edge until it looked like an old dial phone. Cut the tabs and now I'm grinding it smooth with a dremel.... a little more work, but I think it will be the cleanest this way with the limited tools I have for a project like this... Thanks for the feedback all Pics later..
Bartlett 914 |
Oct 17 2006, 01:32 PM
Mark, A Greenlee should punch thru all of it in one shot, no? Maybe not the vinyl, but all else? Looks like he has it already! I think a greenlee might do it in one cut. but I personally wouldn't try it. Remember there is a gap between the 2 pieces of metal. A greenlee will smash them together and deform the outer piece. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:36 AM |
