5 bolt conversion, what should i expect to pay $$$ ??? |
orange914 |
Oct 18 2006, 01:21 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
what is the going $ for:
1 complete front 5 bolt conversion 2 complete rear 5 bolt 3 BOTH complete 5 bolt 4 porshe 5 bolt wheels(rough/generic price) (IMG:style_emoticons/default/mueba.gif) |
brant |
Oct 18 2006, 01:54 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
lots of options that effect price.
you can go 5 bolt by drilling and studding or you can go 5 bolt by bolting in 911 stuff or you can go 5 bolt by bolting in BIG 911 stuff with big brakes, different A-arms, everything... wheels can run anywhere from: $50/each for a cookie cutter to $2000/each for a 7inch 911R fuchs. lots of options. but its possible to do it for a grand. brant |
Eric_Shea |
Oct 18 2006, 02:01 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
There's a lot involved and it depends on what you want to do.
QUOTE 1 complete front 5 bolt conversion For your 73 you could: Purchase drilled 914 rotors - $295.00 (you'll need new bearings and seals) Purchase 911 Struts - $350-$500 plus depending on how complete (brakes, cool strut inserts, new rotors, new bearings) QUOTE 2 complete rear 5 bolt Again, depends. How much work do you want to do yourself. 914 Hubs drilled to 5-lug $135.00 (you'll need new bearings at least) 911 Hubs - $150 +$400-500 for 914-6 stub axles if you buy right (you'll need new bearings as well.) Complete bolt on 5-lug conversion arms $395.00 plus your cores (includes new bushings and bearings). QUOTE 3 BOTH complete 5 bolt Minimum - $295 + $135 = $430 you do all the work and you'll need bearings, seals and rotors. Medium - $350 (or more) + $135 = $485.00 and you'll need bearings, seals and probably rotors all the way around. Medium 2 $350 +$395 = $745.00. You'll probably need from bearings and bushings and the rears will bolt right on. You'll probably need rotors and possibly brakes. Top End - $500 + $650 = $1,150 again, you'll probably need bearings, seals and rotors and possibly brakes. QUOTE 4 porshe 5 bolts (rough/generic price) Are you talking about wheels? Plan on $100 each to $200 each depending on what style and size. 914-6's came with 14" fuchs or 15" steel as a "general" rule (yes, there where various other Mahles and Pedrinni's etc.). The 14's were fairly easy to find for a while there and they could be had for $50-$75 bucks. I haven't seen them much lately but I haven't been looking. A nice one might be the very common 16x6 that came on the front of most 911SC's. Most SC guys moved the 7's on the rear up to the front and got 16x8's for the rears. 16x6's (Fuch's 5 paddle) are still fairly common and the 16" size is still fairly easy to get a tire for. 15x6 is also cool and frankly, for any tire that will fit under a teener, they can be found easily as well. Hope that helps. Eric |
brant |
Oct 18 2006, 02:03 PM
buy Eric's conversion parts.
it will save you all of the headaches and you WILL NOT be able to beat the price! brant |
WaideS |
Oct 18 2006, 02:05 PM
Has been Group: Members Posts: 220 Joined: 25-January 06 From: Valley of the Sun Member No.: 5,475 Region Association: None |
buy Eric's conversion parts. it will save you all of the headaches and you WILL NOT be able to beat the price! brant I agree completely, look at Eric Shea's links and you can find a ton of info and pricing for the "right stuff at the right price" (IMG:style_emoticons/default/thumb3d.gif) |
Eric_Shea |
Oct 18 2006, 02:07 PM
brant |
Oct 18 2006, 02:11 PM
eric.....
psss... when do I get my monthly kick back? psss.... No.. seriously Orange914 you won't be able to beat Eric's prices, knowledge, or customer service! most people collect the parts over time (ie: wheels one month, tires another, suspension bits yet another) and then bolt it all together on a weekend. good luck with the project. brant |
markb |
Oct 18 2006, 02:29 PM
buy Eric's conversion parts. it will save you all of the headaches and you WILL NOT be able to beat the price! brant (IMG:style_emoticons/default/agree.gif) If I didn't already have the suspension off of an original 6, I'd be buying Eric's setup. |
orange914 |
Oct 18 2006, 03:18 PM
There's a lot involved and it depends on what you want to do. QUOTE 1 complete front 5 bolt conversion For your 73 you could: Purchase drilled 914 rotors - $295.00 (you'll need new bearings and seals) Purchase 911 Struts - $350-$500 plus depending on how complete (brakes, cool strut inserts, new rotors, new bearings) QUOTE 2 complete rear 5 bolt Again, depends. How much work do you want to do yourself. 914 Hubs drilled to 5-lug $135.00 (you'll need new bearings at least) 911 Hubs - $150 +$400-500 for 914-6 stub axles if you buy right (you'll need new bearings as well.) Complete bolt on 5-lug conversion arms $395.00 plus your cores (includes new bushings and bearings). QUOTE 3 BOTH complete 5 bolt Minimum - $295 + $135 = $430 you do all the work and you'll need bearings, seals and rotors. Medium - $350 (or more) + $135 = $485.00 and you'll need bearings, seals and probably rotors all the way around. Medium 2 $350 +$395 = $745.00. You'll probably need from bearings and bushings and the rears will bolt right on. You'll probably need rotors and possibly brakes. Top End - $500 + $650 = $1,150 again, you'll probably need bearings, seals and rotors and possibly brakes. QUOTE 4 porshe 5 bolts (rough/generic price) Are you talking about wheels? Plan on $100 each to $200 each depending on what style and size. 914-6's came with 14" fuchs or 15" steel as a "general" rule (yes, there where various other Mahles and Pedrinni's etc.). The 14's were fairly easy to find for a while there and they could be had for $50-$75 bucks. I haven't seen them much lately but I haven't been looking. A nice one might be the very common 16x6 that came on the front of most 911SC's. Most SC guys moved the 7's on the rear up to the front and got 16x8's for the rears. 16x6's (Fuch's 5 paddle) are still fairly common and the 16" size is still fairly easy to get a tire for. 15x6 is also cool and frankly, for any tire that will fit under a teener, they can be found easily as well. Hope that helps. Eric so bottom line on a used set up to change over to a complete 5 bolt with wheels that would be driver status complete could realisticly be done around $2000??? |
brant |
Oct 18 2006, 03:30 PM
maybe less if your willing to do some of the labor and don't have to have the most expensive wheels.
a lot of guys do real NICE 5 bolt conversions for less. brant |
Aaron Cox |
Oct 18 2006, 03:42 PM
its been hashed over MILLIONS of times here....
my route.. complete 73 911 Front end (steal - 125 bucks) had koni's (sold) and i rebuilt the calipers, new bearings, new rotors, new bushings, new inserts..... rear... i called my man Eric 'E - dawg' shea... dropped 400 ish for COMPLETE rear arms, painted, new bearings, bushings, and hubs have been drilled and studded... all i did was write the check (no bearing instalations for me (IMG:style_emoticons/default/smile.gif) ) and i bought 914/6 rotors for the rear...... (you CAN redrill /4 rotors) |
BK911 |
Oct 19 2006, 10:06 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
So why do the conversion? ~$2k is a lot of money to put into a car just because. Most likely you will not see the return if you decide to sell.
I already have most of the parts but I can't convince myself that this is a worthy conversion. OT: I also have a freshly rebuilt -6 that I can't decide what to do with. |
brant |
Oct 19 2006, 10:28 AM
what displacement is the -6?
(you should definitely sell it to me) |
Lo-Fi Version | Time is now: 8th May 2024 - 03:51 PM |
