Bilseins Rear coil-over delema, Notches |
Teknon |
Oct 18 2006, 06:03 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
Well I'm puzzeled. Got these pretty yellow Bilstein Sports. That should go on the car. (IMG:style_emoticons/default/confused24.gif)
BUT I am not sure what notch to put the coil plate on. There are six rings on the shock, they came with the clip on the bottom ring. But when the coils go on it is to far to clamp down on them. The coils are 165# progressives. I don't want to do this without consulting the Masters. (IMG:style_emoticons/default/burnout.gif) Also do you need the bump stops? I heard you don't with Bilseins, internal stops I heard. The succession of parts are 1-lower coil plate, 2-the coil, 3-upper coil plate, 4-washer, 5-long bolt, 6-set of bushings, 7- top cap and 8- top nut. The workshop manual shows other idems I don't have. Thanks, Joe (IMG:style_emoticons/default/huh.gif) |
Aaron Cox |
Oct 18 2006, 06:09 PM
i used third notch up from bottom.... but that is pretty low...
try third from top.... and it takes 5 min to change.... so have fun |
davep |
Oct 18 2006, 06:10 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The Bilsteins still use the bump stops. Raise the perch until the spring is slightly compressed.
Aaron Cox |
Oct 18 2006, 06:11 PM
The Bilsteins still use the bump stops. Raise the perch until the spring is slightly compressed. i disagree with that assesment..... aftermarket springs are inherently shorter... and dont require a spring compressor... even at the second to top perch, my springs still didnt engage the upper hat at full extension |
Teknon |
Oct 18 2006, 06:28 PM
The perch is still loose on the 4th notch up. The fifth up or 2nd down notch compress the spring enough to keep it in place.
Is the sequence of assembly correct? (IMG:style_emoticons/default/cool_shades.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 01:19 PM |
