HELP!, Stripped an exhaust stud! |
Dads914 |
Oct 19 2006, 05:38 PM
Greg Group: Members Posts: 49 Joined: 21-June 06 From: So. Cal. Member No.: 6,277 |
I'm looking for help! I stripped one of my head studs and need someone in or near the San Fernando valley who will let me rent (or borrow) their helicoil tools or whetever is used for that kind of repair (including the breakoff tool. I will have the helicoil so I just need the tools). Can anyone here help a fellow teener? Thanks for your help.
Greg |
SGB |
Oct 19 2006, 07:33 PM
Sure Greg- oh wait I don't have the tool.... And I live in Alabama. Good luck, man. You prolly have more club members in your neighboorhood than I have in my State so I'll bet its not a problem.
Well, y'know I read the thread and saw it was going down. |
cantley914 |
Oct 19 2006, 08:44 PM
Pipeline surgeon Group: Members Posts: 306 Joined: 15-June 04 From: Cantley, Qc Canada Member No.: 2,210 |
I'm looking for help! I stripped one of my head studs and need someone in or near the San Fernando valley who will let me rent (or borrow) their helicoil tools or whetever is used for that kind of repair (including the breakoff tool. I will have the helicoil so I just need the tools). Can anyone here help a fellow teener? Thanks for your help. Greg Hey dad`s !!! What size do you need? I have 10mm X 1.25 Didn`t get a chance to look in my book for the size. Let me know Steph |
Gary# |
Oct 19 2006, 08:52 PM
Member Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 |
You might be able to have the proper tool loaned/rented to you at the same flaps
when you buy the helicoil. Worth a shot. Call around. My local napa will loan you some special tolls. Gud Luck. Not a fun job. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/whack_3.gif) |
rcrgrl |
Oct 19 2006, 08:53 PM
Member Group: Members Posts: 202 Joined: 19-April 06 From: San Diego, CA Member No.: 5,893 |
i could be confused, but i think the only tools you need should come with the helicoil at the parts store - it should include the tap, and the insertion tool. last one i did was for a spark plug so that might be different, but it included everything i needed and i had to buy it anyway to get the actual helicoil part...
cantley914 |
Oct 19 2006, 09:37 PM
i could be confused, but i think the only tools you need should come with the helicoil at the parts store - it should include the tap, and the insertion tool. last one i did was for a spark plug so that might be different, but it included everything i needed and i had to buy it anyway to get the actual helicoil part... (IMG:style_emoticons/default/agree.gif) But they come in a kit with 12 helicoils + the chaser + the inserting tool=approx$75.00 I know I had to buy a whole kit to repair the timing belt tensionner on my 2001 Civic. !! I have some left + the req`d tools if it can help anyone. Steph (IMG:style_emoticons/default/beerchug.gif) |
bd1308 |
Oct 19 2006, 09:39 PM
he needs a end tap, one with a flat end to it, so he can thread a hole that ends in the head.
I have a helicoil tool that I used to patch the transmission speedo sender hold-down bolt. it worked fine, I can mail you mine if you want. |
Mueller |
Oct 20 2006, 01:37 AM
Easy, just use a bolt of the proper size and modify the end with a file or grinder.
Thread the insert onto the bolt, you'll be able to see where you'll have to grind down to get the bolt to "drive" the insert around. You'll have to play with the angle a little bit, but you should be able to figure it out in a few minutes of trial and error. I ended up having to do this a few times since the kits at my FLAPS have a plastic insert tool with a metal tip that fails. As for the breakoff tool, nothing special about that either, use another bolt that is smaller than the minor diameter (slips thru the insert)....a smooth rod might be better so it does not get hung up on the threads when you smack it... |
Dads914 |
Oct 20 2006, 11:26 AM
Easy, just use a bolt of the proper size and modify the end with a file or grinder. Thread the insert onto the bolt, you'll be able to see where you'll have to grind down to get the bolt to "drive" the insert around. You'll have to play with the angle a little bit, but you should be able to figure it out in a few minutes of trial and error. I ended up having to do this a few times since the kits at my FLAPS have a plastic insert tool with a metal tip that fails. As for the breakoff tool, nothing special about that either, use another bolt that is smaller than the minor diameter (slips thru the insert)....a smooth rod might be better so it does not get hung up on the threads when you smack it... I did end up finding the helicoil kit that comes with a few inserts and the insert tool, so I'm just going to buy that. The breakoff tool is where I thought I had a problem, but I think you might have just solved that thanks muller. Thank you everyone else for your help keeping the topic at the top so it would be seen and thanks for your offers of help. The club is always the place to be for great advice. Greg (IMG:style_emoticons/default/drunk.gif) |
jk76.914 |
Oct 20 2006, 03:19 PM
Did you consider a stepped stud? I used one on my engine when it went back together. I can't remember exactly, but I think it was 9mm at one end and 8mm at the other. Both ends are the same pitch, so when you tap the 9mm thread, the new threads cut what's left of the old threads deeper. Pretty easy repair.
Seems to me that the 1.8 used these as factory standard. (Someone who's done more than one engine should comment at this point!) Jim |
Brad Roberts |
Oct 20 2006, 03:23 PM
Jim nailed it.
I have been buying the oversized studs from Zims for years. This is a very good solution. The helicoils always feel "loose" to me when installing the new stud. I think I'll timesert my next one. B |
old dkp |
Oct 20 2006, 03:30 PM
Newbie Group: Members Posts: 12 Joined: 21-September 06 From: san jose Member No.: 6,885 |
Jim nailed it. I have been buying the oversized studs from Zims for years. This is a very good solution. The helicoils always feel "loose" to me when installing the new stud. I think I'll timesert my next one. B The step-stud is 9x8 thread pitch 1.25 I also like Time Serts but you can use the Perma-Thread heli-coil kit part# 1221-309 9 x 1.25 they cost about $35.00. or would you like to borrow mine? i can send it priority mail? i m in the bay area. Christo..... |
BMXerror |
Oct 20 2006, 06:44 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Oh shit. I just posted about a stripped exhaust stud JUST NOW, and I didn't see this. Sorry for the redundancy.
Mark D. |
BMXerror |
Oct 20 2006, 06:56 PM
I looked on Zims website and couldn't find any stepstuds. Is it a special order sort of thing, where you have to specifically ask? Sorry for the Hijack Dads. (IMG:style_emoticons/default/smile.gif)
Mark D. |
PORobinSCHE |
Oct 20 2006, 07:45 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
also my want to use a dab of green locktite when eintalling the heli-coil. #609 works good. it will keep the insert from backing out later
Robin BTW if you folk didn't all live on the left coast we'd probably be able to help more (IMG:style_emoticons/default/chairfall.gif) |
Jake Raby |
Oct 20 2006, 07:47 PM
I have chromoly studs in 8x8, 9x8 and 10x8 just for these purposes..
jk76.914 |
Oct 20 2006, 07:49 PM
Sammy |
Oct 20 2006, 07:59 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
$25 at the FLAPS should get you everything you need, except the drill motor and a steady hand.
BMXerror |
Oct 21 2006, 10:30 AM
Hey Jake. You said you had 8X10mm stepped exhaust studs for the T4, but all I found on your site were the rocker studs. Is that what you were talking about? Do those work for exhust studs? If so, they are 1.50 thread pitch on the big side, right? Thanks.
Mark D. |
Jake Raby |
Oct 21 2006, 11:45 AM
Those rocker studs will work for exhaust studs... They work very well!
Lo-Fi Version | Time is now: 9th May 2024 - 09:38 AM |
