some body in puget sound area go get this, from C/L |
messix |
Oct 20 2006, 06:15 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i dont have room for this at least for the parts.
rjames |
Oct 20 2006, 06:56 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
ahh if only I had room in the garage, the extra $ and a wife that wouldn't make me live in it if I bought it, I'd be all over it (IMG:style_emoticons/default/biggrin.gif)
If someone else picks it up, I have a welder- I'd be happy to fix the longs- provided I get to pull a piece or two off it it first! (IMG:style_emoticons/default/cool.gif) |
sixnotfour |
Nov 5 2006, 06:38 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
well here it is, turns out the rust is the outer rocker, no biggy,
battery tray rusty,no holes, all else solid, Bad news no run. prime system bad fuel line ,gas spraying straight up , New fuel line Good news , new plugs, cap ,rotor ,wires , already installed PO's friend Bad news no spark Replace the only thing they didnt , the condensor ,yes =spark More bad no start prime -starts dies ? Oh look new oil and filter,PO's friend Tighten oil cap starts and runs , no smoke ,runs good then quits Good news out of gas. more gas runs and drives needs pedal bushings ,tires, and push rod seals. body straight was yellow repaint white, not so bad except for the black bomb can job under the hoods. finally look at the odometer 80k seems correct. Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 03:01 AM |
