messix
Oct 20 2006, 06:15 PM
i dont have room for this
at least for the parts.
rjames
Oct 20 2006, 06:56 PM
ahh if only I had room in the garage, the extra $ and a wife that wouldn't make me live in it if I bought it, I'd be all over it
If someone else picks it up, I have a welder- I'd be happy to fix the longs- provided I get to pull a piece or two off it it first!
sixnotfour
Nov 5 2006, 06:38 PM
well here it is, turns out the rust is the outer rocker, no biggy,
battery tray rusty,no holes, all else solid,
Bad news no run.
prime system bad fuel line ,gas spraying straight up ,
New fuel line
Good news , new plugs, cap ,rotor ,wires , already installed PO's friend
Bad news no spark
Replace the only thing they didnt , the condensor ,yes =spark
More bad no start
prime -starts dies ?
Oh look new oil and filter,PO's friend
Tighten oil cap starts and runs ,
no smoke ,runs good then quits
Good news out of gas. more gas runs and drives needs pedal bushings ,tires,
and push rod seals.
body straight was yellow repaint white, not so bad except for the black bomb can job under the hoods.
finally look at the odometer 80k seems correct.
