What should be done about small rust bubbles? |
dhopkins |
Oct 21 2006, 05:49 PM
Member Group: Members Posts: 50 Joined: 7-July 04 From: Rydal, Pa Member No.: 2,315 |
On a few places on my '76 tweener there are little tiny rust bubbles. Should I leave them alone or open them up and treat them with anti-rust paint?
Don ----------------------------------------- 1969 911S 1976 914 2.0 1981 911SC |
Katmanken |
Oct 21 2006, 05:53 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Rust never sleeps so don't leave them alone.
Bubbles means bad. You can't just puncture a rust bubble like a zit and put a little protective paint in there. Usually means a lot more is lurking under the paint and a lot of work. Ken |
So.Cal.914 |
Oct 21 2006, 11:15 PM
You can use a dremel or mini grinder and grind it down until rust is gone. If
it goes all the way thru the metal, if small enough, you can weld a small bead in the hole and grind that down. Or plug with lead but I would weld it . |
G e o r g e |
Oct 21 2006, 11:21 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
nothing, just think about them as textured paint (IMG:style_emoticons/default/happy11.gif)
but if it was my car i would listen to the first 2 post (IMG:style_emoticons/default/beerchug.gif) |
highways |
Oct 22 2006, 03:09 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
My 'little bubbles' became the size of oranges or watermelons. Once begining to clean I'd see more metal getting infected. Some areas it would even look like you could stop wire brushing- but I'd suspect more in certain directions (even under perfectly good looking paint) so I'd give it a go, and low and behold..... [insert rust gremlin smiley].
So I would wirebrush, metal etch, water rinse, acetone dry, and zero rust paint. I think I got it under control now. Took about 1/2 of each trunk down to bare metal, as well as entire floorpans, firewall, ect. |
JPB |
Oct 22 2006, 08:18 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Rust bubbles, you lucky bastard!! I hope the paint lasted you about five years like a new car and that its time for another one. If not (IMG:style_emoticons/default/sad.gif) I sorry, you lucky bastard. Lucky? Hell ya because it gives you time to invest in stuff like ahhhhh, side grinder and cutoof wheels, drill and rivet gun, body filler not "bondo", and huge new fiberglass parts like fenders, lids, bumpers, door skins ect.....
(IMG:style_emoticons/default/beer.gif) All the other spots that are covered by the body is Por-15 zonage. That rust my friend is a blessing so now chop chop at will! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) |
Katmanken |
Oct 22 2006, 09:35 AM
There is a reason I will buy an old car with crappy oxidized worn out paint before buying one with shiny new paint.
Crappy paint shows exactly what needs to be fixed. Seen too many people in Florida buy shiny new painted old cars and have rust pop up a year later. Paint it once, not twice. Ken |
Lo-Fi Version | Time is now: 20th May 2024 - 03:27 AM |
