914 brake conversion |
tomburdge |
Oct 23 2006, 06:43 AM
Newbie Group: Members Posts: 33 Joined: 11-August 05 From: Hillsborough,N.J. Member No.: 4,576 |
Hey guys,I could use some help.
I run an RSR strut on the front of my F prod car.Way back when I had the stock 914 spindle welded to it. I would now like to use the( rules permitted )"M" caliper and vented rotor and would like to know if anyone makes an adapter that would permit me to put the vented rotor on the stock 914 spindle. My rational here is #1:Better cooling #2: Better overall braking because of larger pistons thus better clamping forces. Are these assumptions correct and would their be any other benefits? Also has anyone produced a 911 hub that accepts four bolt wheels.I heard that Pelican may offer such a thing. Thanks in advance for any and all input. Tom B. |
Matt Romanowski |
Oct 23 2006, 07:48 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I think you're talking exactly about the hub that Mike Mueller made up. Send him a pm.
Mueller |
Oct 23 2006, 09:43 AM
Yes, a new hub is available that bolts onto '73 and later spindles that allows you to use 911 "M" calipers and 911 vented rotors. They use stock 914 wheel bearings.
they are being used successfully on cars ranging from bone stock to V8 conversions to /6 conversion race cars. I highly recommend BBS Racing screw-in studs with these although the stock wheel bolts work. Here are a few threads on the subject: hub talk more hub talk, Johns /6 conversion race car |
Eric_Shea |
Oct 23 2006, 09:59 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yup... that's the $hit. Major benny is cooling.
Lo-Fi Version | Time is now: 9th May 2024 - 12:14 AM |
