> Rejet the 44's or buy some 40's?, Yay, more carb questions.
LowGT
post Oct 24 2006, 12:15 AM
Post #21
1.8 and Proud!
I have a stock 2.0 with dual weber 44's and a unilite. I had the 44's on hand, so if I rejet and change the venturis will it be like a 40idf? Or is there some significant difference between the 44's and 40's that make that not possible? Right now they are pig rich, as expected.
Right now it's:
36 venturis
50 idles
200 air correction
145 main
F11 emulsion
Proposed change #1:
Redo the 44's
32 venturis
45-50 idles
180-210 air correction
120-125 mains
F11 emulsion
(as you can tell, I don't know. From all the posts I searched this seemed like the area people were in with 40idfs)
Proposed change #2:
Sell the 44's, buy a set of 40's. Tune from there.
So which would you do? If you suggest keeping the 44's what would you recommend for jetting venturi?
Thanks! I need all the help I can get. (IMG:style_emoticons/default/biggrin.gif)
LowGT   Rejet the 44's or buy some 40's?   Oct 24 2006, 12:15 AM
Aaron Cox   what cam and what do the heads look like? also.. w...   Oct 24 2006, 12:17 AM
LowGT
- Lo-Fi Version Time is now: 14th July 2025 - 03:48 AM
