914/4 rear 5-bolt problem, can't get calipers on! |
JmuRiz |
Mar 6 2003, 11:27 AM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I have a 914 5-bolt kit that's being installed and the rear caliper will not fit on the 914/6 disk that I was given. Any ideas on what to do. I'd rather not have to machine down a brand new 914/6 rear disk.
Has anyone else had this issue? If so how did you fix it, thanks! Nathan |
Dave_Darling |
Mar 6 2003, 12:27 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Geoff, he says (on the Pelican board) that his problem is not the diameter of the rotor (known problem in some cases), but with the thickness!
I'll say it again--you either have vented 911 rear rotors, not solid 914-6 rear rotors, or you haven't pulled the caliper pistons in far enough. --DD |
Lo-Fi Version | Time is now: 21st May 2024 - 07:45 AM |
