JmuRiz
Mar 6 2003, 11:27 AM
I have a 914 5-bolt kit that's being installed and the rear caliper will not fit on the 914/6 disk that I was given. Any ideas on what to do. I'd rather not have to machine down a brand new 914/6 rear disk.
Has anyone else had this issue? If so how did you fix it, thanks!
Nathan
Bleyseng
Mar 6 2003, 12:25 PM
Yes, the 4 calipers don't have the same clearance as the 6 ones as the 6 disc is a tad larger. So grind out the 4 calipers alittle bit so it fits.
Geoff
Dave_Darling
Mar 6 2003, 12:27 PM
Geoff, he says (on the Pelican board) that his problem is not the diameter of the rotor (known problem in some cases), but with the thickness!
I'll say it again--you either have vented 911 rear rotors, not solid 914-6 rear rotors, or you haven't pulled the caliper pistons in far enough.
--DD
Bleyseng
Mar 6 2003, 12:36 PM
J P Stein
Mar 6 2003, 03:04 PM
I had 914/6 rotors with 914/4 calipers on my car at one time.
The -6 rotors are slighly tihicker....bout .020, IIRC.
Back off the venting clearance screw, push back the pistons and they should go right on. Mine did.
Setting the venting clearance is a PITA. When/if you get to that point, lemmeno and I'll tell ya what I did.
Jeffs9146
Mar 6 2003, 03:42 PM
See section 6 of the workshop manual pages 3.2-2/2 and 3.2-3/1
I dont know if you will be able to read this one:
joea9146
Mar 6 2003, 08:41 PM
On my rear conversion I had a problem with the outer diamater of the rotor had to have it made smaller so the caliper would fit. This was on a 1975....
