914/4 rear 5-bolt problem, can't get calipers on! |
JmuRiz |
Mar 6 2003, 11:27 AM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I have a 914 5-bolt kit that's being installed and the rear caliper will not fit on the 914/6 disk that I was given. Any ideas on what to do. I'd rather not have to machine down a brand new 914/6 rear disk.
Has anyone else had this issue? If so how did you fix it, thanks! Nathan |
J P Stein |
Mar 6 2003, 03:04 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I had 914/6 rotors with 914/4 calipers on my car at one time.
The -6 rotors are slighly tihicker....bout .020, IIRC. Back off the venting clearance screw, push back the pistons and they should go right on. Mine did. Setting the venting clearance is a PITA. When/if you get to that point, lemmeno and I'll tell ya what I did. |
Lo-Fi Version | Time is now: 21st May 2024 - 04:39 PM |
