I think I'm Screwed, or injected |
zen motorcycle |
Nov 9 2006, 09:42 PM
almost not a newbie ( way less than a newbie) Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None |
I got a rebuilt injector as mine was leaking and proceeded to install it. I got everything buttoned up and started to look at the old injector to see where it was leaking exactly
I don't see the tip seal (IMG:style_emoticons/default/sad.gif) Any chance it just disintegrated? I didn't feel anything like a seal while I was inserting the new one. If it was/is still in the injector hole what can I do Thanks |
Scott-thundercat |
Nov 9 2006, 09:56 PM
Member Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 |
none of my injectors had that on em. i know they should of but i couldnt find em either- it ran fine though.
bd1308 |
Nov 9 2006, 11:07 PM
doesnt not running the inner injector seal cause sealing issues and vacuum leaks?
ClayPerrine |
Nov 10 2006, 11:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Yes, they will cause vacuum leaks if they are missing.
Go to O'Reilley's and get a set of injector seals from the help isle. They are for Japanese cars, but they fit a 914 just fine. |
zen motorcycle |
Nov 10 2006, 09:58 PM
Yes, they will cause vacuum leaks if they are missing. Go to O'Reilley's and get a set of injector seals from the help isle. They are for Japanese cars, but they fit a 914 just fine. Let me make this clear I have the new injector installed in the car with a new tip seal. I don't see the old tip seal from the old injector I removed. Could it have been pushed into the cylinder? If so how to remove. Engine has not been turned over yet. |
zen motorcycle |
Nov 12 2006, 05:30 PM
Brian_Boss |
Nov 12 2006, 05:42 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
They do tend to stick in the manifold sometimes so I would check that. If it's not there, I would go ahead and fire it up. I doubt it would makei t into the cylinder and, if it did somehow, it probably wouldn't be disasterous. It's only rubber.
My car had two seals on a couple of the injectors - probably from the PO not noticing they stayed in the manifold. Hope this helps. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:25 PM |
