Complete Newby: Advice on Purchase |
Gusto |
Nov 10 2006, 04:53 PM
Newbie Group: Members Posts: 2 Joined: 5-November 06 From: Santa Clarita, Ca Member No.: 7,154 |
I looked at a '72 1.7 the other day.
The body looks to be in very good shape, the only rust is a small spot on the drivers floor pan (under the pedal box) and the battery tray (but underneath is clean). I don't have any auto repair/maintenance experience (except changing light bulbs and some little things here and there). However, I want to learn. The problems I noticed on the car: 1) Very sloppy shifting. First time driving a 914 and it was really difficult getting into the correct gear...kept going to 4th instead of 2nd, etc. 2) Trouble getting into first gear. You practically had to jam the gearshift into your thigh to get it to stick. 3) Idle was pretty low, but the car didn't stall while idling. 4) While driving, the car would stall at a light as I tried to get into 1st. The car seems like a pretty good deal from my perusing the classifieds here and on ebay. That being said...do you think someone with my inexperience should purchase a car with these types of problems? Any help is greatly appreciated. Thanks. |
G e o r g e |
Nov 10 2006, 05:02 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
i would request one of the non-club members to go with you to look at it they might see something your over looking (IMG:style_emoticons/default/beerchug.gif) |
Howard |
Nov 10 2006, 05:03 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Pictures would help, but you really should try to get a club member to go with you to look at the car. Post a convenient time and place over the weekend and see what happens.
ahdoman |
Nov 10 2006, 05:04 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I looked at a '72 1.7 the other day. The body looks to be in very good shape, the only rust is a small spot on the drivers floor pan (under the pedal box) and the battery tray (but underneath is clean). I don't have any auto repair/maintenance experience (except changing light bulbs and some little things here and there). However, I want to learn. The problems I noticed on the car: 1) Very sloppy shifting. First time driving a 914 and it was really difficult getting into the correct gear...kept going to 4th instead of 2nd, etc. 2) Trouble getting into first gear. You practically had to jam the gearshift into your thigh to get it to stick. 3) Idle was pretty low, but the car didn't stall while idling. 4) While driving, the car would stall at a light as I tried to get into 1st. The car seems like a pretty good deal from my perusing the classifieds here and on ebay. That being said...do you think someone with my inexperience should purchase a car with these types of problems? Any help is greatly appreciated. Thanks. Gusto, I live in Santa Clarita. PM me if you want a second set of eyes to look before you buy. |
GWN7 |
Nov 10 2006, 05:06 PM
Hello and welcome.....
The shifting problems you have mentioned are normal for a 914and can normally be solved with new shifter bushings (their is a aftermarket shifter available that gets rave reviews also) except for problem #4 sounds like opperator error. With old cars you have to learn their quirks. I'd be more concerned about rust on the car than these minor problems. Do you feel you could learn about this car? Do you have space for it? Or a place to work on it? Tools? Will your family object if you spend hours in a cold garage? If you answered yes to at least 3 of those questions, then you too could be a 914 owner (IMG:style_emoticons/default/smile.gif) |
VaccaRabite |
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You are on the left coast, there are lots of fish in that sea. You don't need to jump on this one, unless it is next to free.
Do you know the rust trouble spots to check? Around the jack ports (look behind the rocker panels) and under the battery tray. Personally, I got into these cars with a smattering of car restoration work. I have learned to weld, I am learning tramsmissions, I am learning air cooled engines, I am about to learn a hell of a lot about wiring. And you will too. Don't be afraid, BUY THE BEST CAR YOU CAN AFFORD, realise that its still a 30+ year old car and you will - at some point or another - probably have the thing to peices. WELCOME TO THE CLUB! Zach |
So.Cal.914 |
Nov 10 2006, 05:08 PM
1 & 2 Sounds like typical 914 shifting. The early teeners (tail shift) had more slop
than the post 72's (73-76) did but a short shift kit helps. 3 & 4 The idle can be turned up and a tune up may also help. I don't have any auto repair/maintenance experience (except changing light bulbs and some little things here and there). However, I want to learn. Well it is a 34 year old car so you will get the opportunity to learn. Last but not least (IMG:style_emoticons/default/welcome.png) |
Gary# |
Nov 10 2006, 05:13 PM
Member Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 |
1st of all - (IMG:style_emoticons/default/welcome.png)
--- And then... YES!!! YES!!! YES!!! Buy the car. U might want to get a PPI (pre-purchase inspection) 914Club members help club members. Post a PPI request right here and there may be someone local to you on this board that can help you. --- Sloppy shifting is common to ALL 30 + year old 914's. Replace the shift bushings and the shift linkage coned set screws. U will notice a HUGE difference. First time I drove a friends 914 I ground gears a heck of a lot more than I found 'em. Strange shift pattern. But unique - like the rest of the car!!! Don't worry that your not a mechanic. Neither was anybody else before they "became" a mechanic. And you've got this 914Club ready to help U along. (IMG:style_emoticons/default/driving.gif) Gud Luck!!! |
Gusto |
Nov 10 2006, 05:53 PM
Thanks for all the encouragement. I've read through several how-to articles on improving the shifting...some of it scared me off...sounds really complicated (but then again, one of my goals is to learn).
Hopefully with the club members' help...I'll be joining the owners!! |
mcbain77 |
Nov 10 2006, 07:49 PM
Member Group: Members Posts: 155 Joined: 27-January 06 From: Houston, TX Member No.: 5,485 |
Thanks for all the encouragement. I've read through several how-to articles on improving the shifting...some of it scared me off...sounds really complicated (but then again, one of my goals is to learn). Hopefully with the club members' help...I'll be joining the owners!! (IMG:style_emoticons/default/welcome.png) In the past year I have learned so much about this car and I still learn something new everyday! I would also suggest investing in some metric tools and getting a Haynes repair manual to get you along. It makes great bathroom reading! |
LowGT |
Nov 10 2006, 10:55 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
Do you feel you could learn about this car? Do you have space for it? Or a place to work on it? Tools? Will your family object if you spend hours in a cold garage? If you answered yes to at least 3 of those questions, then you too could be a 914 owner (IMG:style_emoticons/default/smile.gif) Don't forget, "Are you attached to the money in your savings account?" (IMG:style_emoticons/default/welder.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:30 PM |
