Removing rear sway bar, trick to get drop links off |
GaroldShaffer |
Nov 9 2003, 09:54 PM
OK dumb question. I got the rear sway bar unbolted
finally from the chassis, was is the correct way to get the drop link off from the bottom of the shock?? Does it just pop off?? - Garold |
seanery |
Nov 9 2003, 09:55 PM
yes.
Don't forget to save the ball end from the shock mounts. |
GaroldShaffer |
Nov 9 2003, 09:57 PM
QUOTE Don't forget to save the ball end from the shock mounts. OK, how do you remove those?? |
Jeroen |
use a "pickle fork"
cheers, Jeroen |
seanery |
Nov 9 2003, 10:00 PM
the ball ends are part of the lower shock bolts, just unbolt em and pull 'em out.
GaroldShaffer |
Is that a dill pickle fork (IMG:style_emoticons/default/cool_shades.gif)
seanery |
Nov 9 2003, 10:01 PM
Here is a pic of everything that you need to take with the rear.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1064460077.jpg) |
GaroldShaffer |
Nov 9 2003, 10:05 PM
anything else I need to do before I remove that bolt?? This
is comming off a parts car. |
seanery |
Nov 9 2003, 10:07 PM
watchout for the wheels drooping when you do. If you don't need them on the car take 'em off.
now would be a good time to remove the whole rear suspension. |
GaroldShaffer |
Nov 9 2003, 10:13 PM
QUOTE now would be a good time to remove the whole rear suspension All I want is the sway bar & hardware (IMG:style_emoticons/default/cool.gif) everything else is scrap. I relly don't want to mess with the suspension. |
Nov 9 2003, 10:20 PM
Resident German Group: Admin Posts: 41,643 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(itsa914 @ Nov 9 2003, 08:13 PM) All I want is the sway bar & hardware (IMG:style_emoticons/default/cool.gif) everything else is scrap. I relly don't want to mess with the suspension. take it out anyways. there could be some hidden treasure in there (IMG:style_emoticons/default/wink.gif) like, a whole stack of alignement shims, or adjusteable shocks, or unbent trailing arms. sell (or give it to me for free (IMG:style_emoticons/default/smile.gif) ) every little piece of it that's not rusted ... Andy |
914werke |
Nov 9 2003, 11:00 PM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Garold, assuming this is an otherwise stock LE (rust & re-paint notwithstanding) It would be interesting to note: Rear shocks- Make, Front strut housing & inserts- make?
GaroldShaffer |
Nov 10 2003, 04:19 PM
QUOTE take it out anyways. there could be some hidden treasure in there like, a whole stack of alignement shims, or adjusteable shocks, or unbent trailing arms OK how do you tell for sure that the trailing arms are not bent? They look ok, I haven't taken them off yet, just wondering. Also Do I need to compress the spring on the shock before I remove it or can it be removed as one complete piece? - Garold |
Nov 10 2003, 05:23 PM
QUOTE(itsa914 @ Nov 10 2003, 02:19 PM) OK how do you tell for sure that the trailing arms are not bent? They look ok, I haven't taken them off yet, just wondering. Also Do I need to compress the spring on the shock before I remove it or can it be removed as one complete piece? as for the trailing arms, ask brad (IMG:style_emoticons/default/wink.gif) if you're asking if you need to compress the spring to remove the shock from the chassis, NO. if you're asking if you need to compress the spring to remove the spring from the shock, MAYBE. if the springs anywhere near stock, you'll be able to compress them by hand if needed. usually, when you unbolt them, you'll notice than there's no pressure on the nut for the last few threads anyways. as always, point them away from you, just in case ... later, Andy |
GaroldShaffer |
Nov 10 2003, 09:06 PM
QUOTE if you're asking if you need to compress the spring to remove the shock from the chassis, NO. yep that is what I was asking. Thanks Andy (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 02:01 PM |
