QUOTE(itsa914 @ Nov 10 2003, 02:19 PM)
OK how do you tell for sure that the trailing arms are not bent?
They look ok, I haven't taken them off yet, just wondering.
Also Do I need to compress the spring on the shock before
I remove it or can it be removed as one complete piece?
as for the trailing arms, ask brad
if you're asking if you need to compress the spring to remove the shock from the chassis, NO.
if you're asking if you need to compress the spring to remove the spring from the shock, MAYBE.
if the springs anywhere near stock, you'll be able to compress them by hand if needed.
usually, when you unbolt them, you'll notice than there's no pressure on the nut for the last few threads anyways.
as always, point them away from you, just in case ...
later,
Andy
