Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
(IMG:style_emoticons/default/thumb3d.gif) looking good Mike....I likey.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
nice!!!
so step 1, palm nailer. step 2 - planishing hammer? very cool man! does it wake the kids up? |
Mueller |
nice!!! so step 1, palm nailer. step 2 - planishing hammer? very cool man! does it wake the kids up? yep, palm nailer...word of warning, don't "test" the palm nailer on your hand...ouch.... (IMG:style_emoticons/default/blink.gif) kids are at granndpas house with mommy...time for daddy to play (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
This is really cool. Post a picture of a palm nailer. I think this is THE way to do flairs. John the ghia guy who handformed his (as shown in his avatar- I'm blanking on the screen name though) was having a class in this this past weekend. I would like to learn this. Does it get sofeter as you work it, or do ya just beat the sh!t out of it until it is where you want it? Take some more pictures- difernt angles, etc. Is this the first side?
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Mike, I need to have John Kelly make me a pneumatic planishing hammer. It makes quick work of smoothing out the lumpy-ness.
Aaron, without a planishing hammer setup, it's hammer and dolly work to take out the lumps. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Awesome!!
All to familiar.. Now the hard part... Getting it how you want... THEN making it the SAME on the other side. |
Andyrew |
Scott. John Kelly is the name you want.
The metal is consistant, actually as you go from a flat metal to a rounded metal, the metal becomes stronger, yet ever so slightly thinner. |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
You can get an optional hard rubber plug that threads onto the palm hammer. We use them at work for pressing in PVC t-mold. The plug has about a 1.25" diameter and the impact is spread out much more than the nail fitting
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Pretty good.
Keep going. KT |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
I kind of like that baby GT flair look, keep up the good work.
John Kelly |
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 ![]() |
Way to go Mike! There are a couple of ways to smooth that are faster than hammer and dolly...without a planishing hammer. The first one is a slapper replacing the hammer. It covers more area than a hammer head, so each blow is slightly more effective. The second way is to make a nearly flat die to fit over the bolt in your palmnailer. First use the carriage bolt or my updated tooling (see my album link below) to stretch, then use the nearly flat die (with sand bag on the outside) to go over the area you have stretched. This will do a lot of smoothing for you. Make sure the sand bag is packed really tight with sand. Has your carriage bolt shaft mushroomed yet? I started using a grade eight bolt and homemade dies instead...holds up better. Maybe the rubber die that panel billy mentioned could be used with a piece of hard plastic held on the out side of the fender to smooth after the initial stretching? Depends on how hard, wide, and flat it is.
John www.ghiaspecialties.com http://allshops.org/cgi-bin/community/comm...d=9980138836765 |
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
Just remove the flares off that black car in the background, and weld them on!!!
Nice job at it. do you plan any heat treatement to soften the metal up? Too much streching of the steel might allow it to crack later. Maybe get it hot, then slow cool???? |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
John, I love that thrift store purse idea. CSOB points to you. Mike, nice work. Keep the pics coming. |
John Kelly |
dmenche914, heat is not required. The metal will take a lot of stretching before any failure...especially if you smooth the metal betweeen stretching sessions.
jsteele22, It's a fine line between cheap and frugal (smile). John www.ghiaspecialties.com |
jsteele22 |
Mueller |
thanks for the replys.....
John, would small steel shot work better in the bag? I'm not a fan of the sand dust..... |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
Mike work looks great
after you polish your skills on yours , can i send you 2 rear qtrs that you can turn into a couple of johns flares? (IMG:style_emoticons/default/biggrin.gif) |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
Mueller |
thanks for the replys..... John, would small steel shot work better in the bag? I'm not a fan of the sand dust..... Dampen the sand with a spray mister as you load it in the bag...... it's a sealed leather'ish bag I got from MarkD |
Lo-Fi Version | Time is now: 30th July 2025 - 09:17 AM |
