Rust in the gas tank, no wonder that fuel filter turned red |
SGB |
Nov 12 2006, 07:12 PM
Didn't pull that gear stack yet, but while my car is up on 'stands and the carbs are out, I started to remove the fuel line from the carbs- disconnecting the SS braided line that I ran through a hole with a grommet to the firewall, where it attaches to the original line. I smelled gas and looked and the gas was collecting on the plastic line (drips- running to the lowest point) near the attachment. I drained the rest of the system, and finished pulling the tank. I've gota replace the fuel line too I think. Sure enough, the tank had a surprise inside....
Do I just get it boiled at a radiator place then try to pour por-15 or like that in there? Should I try that before boiling (I'm thinking it can't hurt)? I'm certainly up for lessons learned or bright or dim ideas... Experiences? Advise? Harasment? Attached thumbnail(s) |
PinetreePorsche |
Nov 12 2006, 08:05 PM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
Yeah--my newly-purchased '73 had the orange tone in the filter, too. I took out the tank (take the hood off, carefully, but the rest is easy) Take it to a good radiator shop (phone around) and they'll acid etch it and put in a rubberizing coating. Will last as long as the car unless you use lots of the wrong additive in the tank. Good oportunity to renew the rubber portion of the fuel supply and return lines--with good clamps, too. Be careful not to kink the lines putting back in--although the access hole at the bottom will let you adjuct the line a little. You'll pay the shop a bit over $125--and have to wait two days to a week or so. Mine ran better when cleaned! -Chris (PinetreePorsche)
Allan |
Nov 12 2006, 08:12 PM
Empty it and take it to a radiator shop and tell them to boil and pressure test it.
I did it to mine and it cost me all of $60.00 bucks.... |
SGB |
Nov 21 2006, 09:42 PM
Gas tank reseal is complete. Por 15 stuff worked great. I got quite a lot back when I poured it out, but I dunno if it will cure the same after it has been in a tank and back out.
So.Cal.914 |
Nov 21 2006, 09:49 PM
Did you put Por-15 inside the tank? Or am I misinturpreting the picture.
Dr Evil |
Nov 21 2006, 09:53 PM
POR 15 tank treatment is good stuff. I did it to mine. Dont for get to retap the nipples for the fule lines.
So.Cal.914 |
Nov 21 2006, 10:01 PM
Dr Evil |
Nov 21 2006, 10:05 PM
I hope it is the tank stuff, not sure if regular will suffice.
SGB |
Nov 21 2006, 10:17 PM
Yeah, I wasn't clear. It is por-15 gas tank sealer. You pour it in and seal up the openings (duct tape) and slosh it al around- and around- and around- then pour it back out.
So.Cal.914 |
Nov 21 2006, 10:20 PM
Cool..
Lo-Fi Version | Time is now: 17th May 2024 - 08:22 PM |
