Compression and hydro cam valve adjustment, I'll have a combo platter |
SGB |
Nov 12 2006, 07:47 PM
Our story thus far-
Carbs are off. Plugs are out. Valve covers are off. Compression results: #1: 110 psi #2: 130 psi #3 121 psi #4 125 psi This was AFTER I did a really thorough valve job going around and around to each valve until I was sure they were all 1/2 to 2/3 turn past contact. hmmmm. I studied the orientation of the screw slots on #2. Exhaust about 3:00 oclock, Intake at about 1:30. I reset # 3 screws to more closely duplicate this - required maybe 1/4 to 1/2 turn. Retested compression. Now it was 128 psi. Long story short: I've readjusted the valves again to achieve the highest compression. Didn't increase or decrease any setting more than 1/2 turn one way or the other. #1: still messing with it #2: 130 psi #3 128 psi #4 130 psi This seems like a really optimum setting. -OR- Iz this REALLY STUPID? uh, could be. Opinions? Experiences? Mild interest? Speak to me. (this post edited to correct porely remembered results- #1 especially) Attached thumbnail(s) |
Jake Raby |
Nov 12 2006, 09:59 PM
Scott,
Did you do the test with the throttle wide open?? It appears that you did with the rags shoved in the intakes... The throttle position plays a key role with a compresion test.. Now... Nothing tells the tale like a leak down test. Grab a leak down tester and do the tests with the poiston @ TDC and the engine warm.. Do some searches here for the entire procedure as I explained it to dnhunt a couple of times last year... Leakdown tests are 50% more favorable than a compression test because they not only show an issue, but they also show exactly how bad it is and what the source is (valves, rings, head leaks and etc) |
SGB |
Nov 12 2006, 11:06 PM
Jake-
thank for the ree-ply. The rags were out when I tested- just in for the pic. Will a "pressurize the cylinder and listen" LD test be sufficient? I don't even have a compressor, but can borry one and put the comp tester fitting on there. I'll do a search and try to learn a little more about the whole deal. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:32 PM |
