Fuel Injectors, Different Types |
2-OH! |
Nov 11 2003, 10:56 AM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
As I tear into this 2.0 motor, I find three green injectors and one yellow...Are they different flows and should I go locate another green...Are they generally successfully cleanable and re-install...
2-OH! |
sechszylinder |
Nov 11 2003, 11:31 AM
Member Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
hilow,
different color means different fuel flow rate. The green ones are for the 2.0 l d-jet engine whereas the yellow one belongs to 1,7 l engines. You have to use the green coloured injectors on your 2.0 l engine on ALL four cylinders !! benno |
davep |
Nov 11 2003, 12:48 PM
914 Historian Group: Benefactors Posts: 5,148 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
You should get all your injectors cleaned. That will improve the spray pattern and performance. Replace the tip seals while you are in there. DaveP |
Lo-Fi Version | Time is now: 24th May 2024 - 02:17 PM |
