2-OH!
Nov 11 2003, 10:56 AM
As I tear into this 2.0 motor, I find three green injectors and one yellow...Are they different flows and should I go locate another green...Are they generally successfully cleanable and re-install...
2-OH!
sechszylinder
Nov 11 2003, 11:31 AM
hilow,
different color means different fuel flow rate.
The green ones are for the 2.0 l d-jet engine whereas the yellow one belongs to 1,7 l engines.
You have to use the green coloured injectors on your 2.0 l engine on ALL four cylinders !!
benno
davep
Nov 11 2003, 12:48 PM
You should get all your injectors cleaned. That will improve the spray pattern and performance. Replace the tip seals while you are in there.
DaveP
