Cutting out the trunk, It looiks easy, kinda |
FEF |
Nov 11 2003, 03:08 PM
Newbie Group: Members Posts: 19 Joined: 31-August 03 From: Oregon Member No.: 1,094 |
So, I'm looking at the rear trunk, and I have to admit that It's easy for me to see it gone.
I have a few questions to ask, though. I'm sure bracing is required. Does someone offer a kit, or have all of you made your own? If no one offers a bracing kit, it looks like I could bracet it up, snip out the trunk, then clean up the edges. Any hints? Thanks in advance. |
Jeroen |
Nov 11 2003, 04:34 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Check here for some more ideas
What I don't like about the black car pictured above is that the bracing looks to run back to the center of the dog-bone. Space them out so they end up above the tranny mounting points More important, they didn't cut out the last bit of the old firewall at the shock towers You should, cause that gives you the opportunity to decently weld the shock towers to the frame-rails... (you'll be amazed when you see the crappy connection) cheers, Jeroen |
Lo-Fi Version | Time is now: 17th May 2024 - 07:08 PM |
