Can this be done?, in one day? |
ws91420 |
Nov 19 2006, 05:36 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Is it possible with help to drop an engine, tear it down to install a cam, reassemble and reinstall in one day? (IMG:style_emoticons/default/welder.gif)
davep |
Nov 19 2006, 05:39 PM
I doubt it very much, unless you are talking a full 24 hours and a top notch team.
Why do you want to replace the cam? |
ws91420 |
Nov 19 2006, 05:43 PM
I have carbs w/ a FI cam.
Dr Evil |
Nov 19 2006, 05:49 PM
I know you and I say NO FREAKING WAY! You do not want to try this my friend. Rememeder the golden rule of working on 914s; there is no quick job and all jobs lead to more jobs and more jobs for ever and ever...
This woudl be a good winter project for you because you will need to fix a bunch of things in there while you are in there. Think of all fo the seals and things that will need cleaning. You will be seeing the rings which may need replacing and there is always a possibility of finding a bad cylinder or head issue. I may be able to help you if you do it over the x-mas break. |
sww914 |
Nov 19 2006, 06:26 PM
These cams don't just slide right out the front like a small block chevy.
I don't think you could get it done in a day even if you'd done 20 of them in the last couple of months. |
william harris |
Nov 19 2006, 06:31 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Haste makes waste. Rushing can only lead to disaster. (IMG:style_emoticons/default/blink.gif)
ws91420 |
Nov 19 2006, 07:24 PM
A little background on the motor it is a fresh rebuild thet I did myself w/ less than 750 miles on it (best guess) heads were done w/ new guides, new P&C , new oil pump, bearings, and seals. I realize that I have to splity the case so I am not a total noob to disassembly of the engine. I just nknow the last I disassembled it it took awhile to reassemble it. (old wife not new one was the major problem)
Tom Perso |
Nov 19 2006, 07:37 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
2 days if you hauled @$$ and didn't run into any problems.
Of course, rushing a cam install on a T4 is like playing Russian rulette, but with 5 bullets. (IMG:style_emoticons/default/barf.gif) Tom |
HeloMech |
Nov 19 2006, 07:40 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
I still have my FI cam with my carbs...
Dr Evil |
Nov 19 2006, 07:42 PM
I dont mean to imply that you are inept, Welby. I would not do it either if it were me and I had time.
Joe Bob |
Nov 19 2006, 07:43 PM
I still have my FI cam with my carbs... Run the snot out of it as-is....build another motor, taking yer time....wait until it sucks a seat or runs so well that you decide to sell the built motor, sell it then blow the motor..... (IMG:style_emoticons/default/blink.gif) Oh wait....that's what I did..... (IMG:style_emoticons/default/headbang.gif) |
ws91420 |
Nov 19 2006, 08:14 PM
Sammy |
Nov 19 2006, 08:19 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
It can be done that quickly, but probably not done right.
I've done many emergency repairs over the past 25 years and I've learned that schedule it the worst enemy of quality. You will need to take your time to inspect, clean, and evaluate. If you are in a hurry you will skip those important steps. |
914Sixer |
Nov 19 2006, 10:19 PM
I think it can be done. One hour to drop engine and tranny. Separate engine and tranny and get engine on stand (1 hr). Disassemble engine (2 hrs) . Reassemble engine (2 hrs). I think with the recent rebuild, there should be minimal clean up. Everthing should go back easily.
firstknight13 |
Nov 19 2006, 10:50 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
(IMG:style_emoticons/default/biggrin.gif) go ahead "YOU CAN DO IT" (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/popcorn[1].gif)
type47 |
Nov 20 2006, 06:48 AM
build another motor, taking yer time....wait until it sucks a seat or runs so well that you decide to sell the built motor (IMG:style_emoticons/default/agree.gif) too much work for too little return especially with a freshly rebuilt motor. if it ain't broke, don't fix it. but it's yours and you can do anything you want to. |
Dr Evil |
Nov 20 2006, 08:02 AM
Place your bets! Place your bets! (IMG:style_emoticons/default/rolleyes.gif)
majkos |
Nov 20 2006, 01:23 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
What are the odds??Where can I place my bets? I say, won't be done in a day.You always run into something. Missing just ONE seal, you're set back. BTDT. (IMG:style_emoticons/default/mad.gif) If you go for it , Good luck! (IMG:style_emoticons/default/beer.gif) |
G e o r g e |
Nov 20 2006, 01:32 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
wouldn't it be easier just to put fuel injection back on? (IMG:style_emoticons/default/confused24.gif)
majkos |
Nov 20 2006, 01:33 PM
wouldn't it be easier just to put fuel injection back on? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/chairfall.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:48 PM |
