ws91420
Nov 19 2006, 05:36 PM
Is it possible with help to drop an engine, tear it down to install a cam, reassemble and reinstall in one day?
davep
Nov 19 2006, 05:39 PM
I doubt it very much, unless you are talking a full 24 hours and a top notch team.
Why do you want to replace the cam?
ws91420
Nov 19 2006, 05:43 PM
I have carbs w/ a FI cam.
Dr Evil
Nov 19 2006, 05:49 PM
I know you and I say NO FREAKING WAY! You do not want to try this my friend. Rememeder the golden rule of working on 914s; there is no quick job and all jobs lead to more jobs and more jobs for ever and ever...
This woudl be a good winter project for you because you will need to fix a bunch of things in there while you are in there. Think of all fo the seals and things that will need cleaning. You will be seeing the rings which may need replacing and there is always a possibility of finding a bad cylinder or head issue. I may be able to help you if you do it over the x-mas break.
sww914
Nov 19 2006, 06:26 PM
These cams don't just slide right out the front like a small block chevy.
I don't think you could get it done in a day even if you'd done 20 of them in the last couple of months.
william harris
Nov 19 2006, 06:31 PM
Haste makes waste. Rushing can only lead to disaster.
ws91420
Nov 19 2006, 07:24 PM
A little background on the motor it is a fresh rebuild thet I did myself w/ less than 750 miles on it (best guess) heads were done w/ new guides, new P&C , new oil pump, bearings, and seals. I realize that I have to splity the case so I am not a total noob to disassembly of the engine. I just nknow the last I disassembled it it took awhile to reassemble it. (old wife not new one was the major problem)
Tom Perso
Nov 19 2006, 07:37 PM
2 days if you hauled @$$ and didn't run into any problems.
Of course, rushing a cam install on a T4 is like playing Russian rulette, but with 5 bullets.
Tom
HeloMech
Nov 19 2006, 07:40 PM
I still have my FI cam with my carbs...
Dr Evil
Nov 19 2006, 07:42 PM
I dont mean to imply that you are inept, Welby. I would not do it either if it were me and I had time.
Joe Bob
Nov 19 2006, 07:43 PM
QUOTE(HeloMech @ Nov 19 2006, 05:40 PM)
Run the snot out of it as-is....build another motor, taking yer time....wait until it sucks a seat or runs so well that you decide to sell the built motor, sell it then blow the motor.....
Oh wait....that's what I did.....
ws91420
Nov 19 2006, 08:14 PM
QUOTE(Dr Evil @ Nov 19 2006, 08:42 PM)
I wasn't implying that you thought that just was letting you know that it was a fresh rebuild so that some of the normal issues may be a non problem.
Sammy
Nov 19 2006, 08:19 PM
It can be done that quickly, but probably not done right.
I've done many emergency repairs over the past 25 years and I've learned that schedule it the worst enemy of quality.
You will need to take your time to inspect, clean, and evaluate.
If you are in a hurry you will skip those important steps.
914Sixer
Nov 19 2006, 10:19 PM
I think it can be done. One hour to drop engine and tranny. Separate engine and tranny and get engine on stand (1 hr). Disassemble engine (2 hrs) . Reassemble engine (2 hrs). I think with the recent rebuild, there should be minimal clean up. Everthing should go back easily.
firstknight13
Nov 19 2006, 10:50 PM
type47
Nov 20 2006, 06:48 AM
QUOTE(mikez @ Nov 19 2006, 05:43 PM)
too much work for too little return especially with a freshly rebuilt motor. if it ain't broke, don't fix it. but it's yours and you can do anything you want to.
Dr Evil
Nov 20 2006, 08:02 AM
Place your bets! Place your bets!
majkos
Nov 20 2006, 01:23 PM
QUOTE(Dr Evil @ Nov 20 2006, 07:02 AM)
What are the odds??Where can I place my bets?
I say, won't be done in a day.You always run into something.
Missing just ONE seal, you're set back. BTDT.
If you go for it , Good luck!
G e o r g e
Nov 20 2006, 01:32 PM
wouldn't it be easier just to put fuel injection back on?
majkos
Nov 20 2006, 01:33 PM
G e o r g e
Nov 20 2006, 01:45 PM
QUOTE(majkos @ Nov 20 2006, 11:33 AM)
What's so funny?
