Wider tire or stickier compound?, What would you choose? |
nine14cats |
Nov 21 2006, 07:40 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I was playing with the spec boxsters front wheels today. I have 3 full sets of rims and tires for the thing. 2 sets for Track and 1 set for AX. All are stock rims (these things are CHEAP). Fronts are 17x7 and the rears are 17x8.5's.
I have 245/45/17's on front and 275/40/17's rear. No rubbing. These are Kumho Victoracers. I'm using these to dial in the suspension since they wear pretty well. I have a set of Hoosier R6's on the way to try out as well in 245/40/17's and 275/4017's. I want to try a little less sidewall on the front since the 245's are pinched a little on the rims (looks exactly the same as a 205/50/15 on a 2.0 Fuch). For kicks I put on some rear wheels that have used 255/40/17's. Since they are not as tall as the 245/45's they fit in the wheel well better. And they are about 3/4's of an inch wider in contact patch and over 1 inch wider on the shoulder when you roll it over. And with the 8.5 inch rim, the sidewalls are straight up, not pinched in. Since the 255's fit pretty well (I may need a 5mm spacer to clear the spring collar under load, don't know yet) but they only come in the Victoracer sizes and not in V710's or Hoosiers, would the corresponding gain in footprint offset the compound improvements that the V710's or Hoosiers provide? Or should I try mounting a set of 245's on the 8.5 rims and play with that? My thoughts are that the compounds make a bigger difference than 3/4 of an inch, but on the other hand, if I want to stay budget I could get 2 more rear wheels and just go with 2 sets of rims with Victoracers for track and AX. What do you guys think? Here's some interesting reading from Michelin's engineers regarding the Pilot Sport Cups and sidewall flex and pressures: Michelin Tire Engineering Presentation Thanks, Bill P. |
DanT |
Nov 21 2006, 08:00 PM
Bill,
Consider running 255s on the 8.5s all around...just like a 2.0L teener. That way you can rotate tires to different corners, for tire wear. I have always felt that could be a nice combo for a Boxster. Or would run the 255s front and 275s rear. My preference would be the wider tire/wheel combo on the front considering the weight of the car. So many choices (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/wacko.gif) |
nine14cats |
Nov 21 2006, 08:07 PM
Bill, Consider running 255s on the 8.5s all around...just like a 2.0L teener. That way you can rotate tires to different corners, for tire wear. I have always felt that could be a nice combo for a Boxster. Or would run the 255s front and 275s rear. My preference would be the wider tire/wheel combo on the front considering the weight of the car. So many choices (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/wacko.gif) Hi Dan, I know. So many choices. I'll probably use my datalogger to figure out where I gain or lose using the different tires. The 255's up front look BEEFY! But the Hoosiers are generally 1 to 2 seconds faster on 914's at Thill, so I'm wondering if the same would be true for the Boxster, because even though it's got over 200HP at the crank, it's still a momentum car. Victoracers are mucho cheaper though. But next year the tire fund isn't a problem. But we've got to do well to keep things going with the sponsor. Bill P. |
nine14cats |
Nov 21 2006, 11:20 PM
I agree 255 all the way around could be interesting. Have you considered RA1's? Hi Grant, Everyone I've talked to says that the Hoosiers and Kumho V710's are a cut above the rest. I'm not sure where the RA-1's fall, but they may be on par with Victoracers or a tad below. They seem to be a harder compound than the stickiest of the Dot-R's. I do hear that the RA-1's last a long time, probably because of the harder compound. Bill P. |
groot |
Nov 22 2006, 06:53 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I found out from a Michelin rep that BFG is working on a DOT race tire.....
nine14cats |
Nov 22 2006, 10:12 AM
nine14cats |
Nov 22 2006, 10:14 AM
I agree 255 all the way around could be interesting. Have you considered RA1's? Hi Grant, Everyone I've talked to says that the Hoosiers and Kumho V710's are a cut above the rest. I'm not sure where the RA-1's fall, but they may be on par with Victoracers or a tad below. They seem to be a harder compound than the stickiest of the Dot-R's. I do hear that the RA-1's last a long time, probably because of the harder compound. Bill P. Agreed that Hoosier Roadrace tire is better for ultimate grip at the track. Kuhmo 710 and Hoosier AX tire are far better than anything else for autocross. I'm thinking RA1 would be cheaper alternative for track as the 255/40/17 goes for around $160. I know a few Boxster drivers using stock size RA1's with good results. Hi Grant, What do the folks running RA-1's say about performance in comparison to Victoracers? I'm trying to gauge performance. Thanks, Bill P. |
DanT |
Nov 22 2006, 10:24 AM
Bill,
Jeff Reitmeir and Jim Lane had them on their 924 hot rod for the 2005 season...their feedback on the RA1s was...and I quote. "They are JUNK" Good in the rain, and junk on a dry track. take that for what it is worth.. (IMG:style_emoticons/default/biggrin.gif) |
grantsfo |
Nov 22 2006, 12:13 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Bill, Jeff Reitmeir and Jim Lane had them on their 924 hot rod for the 2005 season...their feedback on the RA1s was...and I quote. "They are JUNK" Good in the rain, and junk on a dry track. take that for what it is worth.. (IMG:style_emoticons/default/biggrin.gif) RA1 isnt an AX tire ( does require some heat), but it is a little softer/stickier than Victoracer. I wouldnt call the RA1 junk for a cheap track tire. I prefered them over Victoracers I ran. I also have been reading good things about Nitto NT-01. Doesnt sound like a Hoosier or Kuhmo slick competitor, but certainly right in there with Victoracers and the RA1. They are under $200 per tire for Boxster sizes. General consenus is that Victoracer, RA1, NTO1 are a second or two a lap off Hoosier DOT R rubber based on track drivers I have spoken with over the past year. For AX the Kuhmo 710 and Hooseir AX tires rule for DOT rubber. I have a question for you since you have driven both DOT R and full on race tires. Given surface at Alameda what kind of an advantage do you think race slicks have over DOT R tires in AX? I'm seriously considering upgrading to race slicks next year. |
DanT |
Nov 22 2006, 12:21 PM
Bill, Jeff Reitmeir and Jim Lane had them on their 924 hot rod for the 2005 season...their feedback on the RA1s was...and I quote. "They are JUNK" Good in the rain, and junk on a dry track. take that for what it is worth.. (IMG:style_emoticons/default/biggrin.gif) While RA1 isnt an AX tire ( does require some heat), but it is a little softer/stickier than Victoracer. I wouldnt call the RA1 junk for a cheap track tire. I prefered them over Victoracers I ran. I personally have not used RA1s but had considered them for a long lasting track tire. you can still get them in 205x50x15 for $120...that is a good bang for the buck... (IMG:style_emoticons/default/smile.gif) |
Brad Roberts |
Nov 22 2006, 12:39 PM
Hi Bill,
I think the 255 F+R would work great for the Boxster 2.5 car. The higher HP engines in the Boxster would probably work better with the 275. GoodYear showed a DotR that looked like a 2 year old Hoosier at a NHRA Drag Racing event early last year. I spoke about it on the site, but dont know what happened to it. I like the idea of running the same size F+R. B |
nine14cats |
Nov 22 2006, 12:54 PM
Hi Bill, I think the 255 F+R would work great for the Boxster 2.5 car. The higher HP engines in the Boxster would probably work better with the 275. GoodYear showed a DotR that looked like a 2 year old Hoosier at a NHRA Drag Racing event early last year. I spoke about it on the site, but dont know what happened to it. I like the idea of running the same size F+R. B Do you think the width is a gain over the compound? The 255 size only comes in the Victoracers or RA-1's, not in the Hoosier R6's. Bill P. |
Randal |
Nov 22 2006, 01:32 PM
My vote is for qualifying tires, i.e., half price. 245.45.18's slicks are available in (equivalent) 250 or 430 compounds. 275's are also available, but don't think they would fit. (IMG:style_emoticons/default/sawzall-smiley.gif) If you want 17's you can get (various) DOT's, but not slicks. Ummm..... I wonder what Lucille would feel like with 245 slicks all around on an AutoX course. (IMG:style_emoticons/default/smile.gif) Or how about Sears? (IMG:style_emoticons/default/happy11.gif) |
nine14cats |
Nov 22 2006, 01:47 PM
My vote is for qualifying tires, i.e., half price. 245.45.18's slicks are available in (equivalent) 250 or 430 compounds. 275's are also available, but don't think they would fit. (IMG:style_emoticons/default/sawzall-smiley.gif) If you want 17's you can get (various) DOT's, but not slicks. Ummm..... I wonder what Lucille would feel like with 245 slicks all around on an AutoX course. (IMG:style_emoticons/default/smile.gif) Or how about Sears? (IMG:style_emoticons/default/happy11.gif) Yup, I'm looking at the slicks, but it would force a huge investment in rims (~$4K for 2 sets) and the biggest thing I found is that since I have a 1997 tub, the car will need to be re-inforced at the rear suspension points to accomodate 18 inch rims (supposedly). This one may not be that big of a deal because I fully expect to see some issues on the tub once we start tracking it regularly. The weakest links always start breaking.... (IMG:style_emoticons/default/laugh.gif) For cost containment I'm thinking of staying away from slicks to keep me from pouring more money into the endless sink hole of racing. I can't challenge for TTOD in AX with a Spec Boxster and I can't be the fastest on the track with a 2.5L motor...so I'm leaning towards leaving it Boxster Spec and encouraging more people to join me in a spec class. Bill P. |
Brad Roberts |
Nov 22 2006, 03:41 PM
I personally beleive compound is more beneficial than width on a low powered car.
I spoke with Tony Heyer last night. He has a customer (and himself) interested in building two more Spec cars for NorCal. B |
Brad Roberts |
Nov 22 2006, 03:44 PM
I have heard about the chassis difference several times, but I have yet to have anyone actually show me the difference between the two.
Remember: Michael Lansky ran his Boxster race car HARD for years on slicks with PCA club racing. He didnt have an issue with the chassis (and I kept up with him/it) Once you tie the cage into the tub.. I think the potential issues go away. B |
nine14cats |
Nov 22 2006, 04:44 PM
I have heard about the chassis difference several times, but I have yet to have anyone actually show me the difference between the two. Remember: Michael Lansky ran his Boxster race car HARD for years on slicks with PCA club racing. He didnt have an issue with the chassis (and I kept up with him/it) Once you tie the cage into the tub.. I think the potential issues go away. B CCW made Lansky's 18 inch rims. They already have the offsets on file for a stock bodied Boxster running 18 inch Radial slicks. $2K a set. Payback on a set versus tire cost of New Hoosiers versus used Radial slicks is about 2 years. That's for one set of rims. Decisions..... Bill P. |
Randal |
Nov 22 2006, 05:26 PM
I have heard about the chassis difference several times, but I have yet to have anyone actually show me the difference between the two. Remember: Michael Lansky ran his Boxster race car HARD for years on slicks with PCA club racing. He didnt have an issue with the chassis (and I kept up with him/it) Once you tie the cage into the tub.. I think the potential issues go away. B CCW made Lansky's 18 inch rims. They already have the offsets on file for a stock bodied Boxster running 18 inch Radial slicks. $2K a set. Payback on a set versus tire cost of New Hoosiers versus used Radial slicks is about 2 years. That's for one set of rims. Decisions..... Bill P. Just a minute while I fit this marketing hat on my head. (IMG:style_emoticons/default/biggrin.gif) Wonder if a sponsor would want to invest that $4K in rims for the slicks? Spec. Boxer finishing in the top 5 in one of California's hottest AutoX venues says something to potential customers. Want me to do an ROI on that? (IMG:style_emoticons/default/happy11.gif) (Actually their break even (figuring 40% margin) is $10K in parts sales; or parts for 1 spec. boxer "conversion." |
Brad Roberts |
Nov 22 2006, 05:39 PM
I want to learn how to go after the BIG sponsors.
What does it take? B |
Trekkor |
Nov 22 2006, 11:07 PM
Lo-Fi Version | Time is now: 5th May 2024 - 02:46 PM |
