QUAD GAUGE, The prototype is done! |
marks914 |
Nov 23 2006, 10:18 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Here is the Quad Gauge project I have been working on.
Sorry about the fingerprints on the glass. I wanted to gauge interest on making a few of these. They are designed for use in V8 cars, but the senders have metric adapters. I could probably use metric scale on the gauges as well. Once I get rolling I am going to try to keep the price below $250. Does that sound reasonable? I can see why Some speedo shops charge $500. The gauge lights up pretty good at night thanks to new LED lighting. The reserve light is retained, but no e-brake indicator as of yet. Still a few tweeks to do, but that is basically it. Mark Attached image(s) |
marks914 |
Nov 23 2006, 10:19 AM
Here is a pic at night, its a bit hard to see, but you get the picture.
jd66921 |
Nov 23 2006, 10:22 AM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
I wopuld LOVE one of those! I assume you would sell the complete unit,
including gauges, minus the senders? Jeff |
jwalters |
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/beerchug.gif) Excellent job bro! Pricing is very reasonable - would suggest you allow flex in pricing to reflect efforts and parts availability, make sure you pay yourself!
Things like this are coveted by this crowd! Keeps the dash sano AND gives the things most want! J |
marks914 |
Nov 23 2006, 10:30 AM
Thanks,
The gauge will include senders, wiring, everything required. Mark |
tomkirkcis |
Nov 23 2006, 10:42 AM
Newbie Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
I would certainly be interested, please put me in line.
smontanaro |
Nov 23 2006, 10:52 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Will it work in a /6?
Thx, Skip |
pjhaun |
Nov 23 2006, 10:59 AM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Is it possible to get this gauge with a white face?
Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
marks914 |
Nov 23 2006, 11:10 AM
Will it work in a /6? Thx, Skip Is it possible to get this gauge with a white face? Thank You!!!! Phillip J. Haun Oak Harbor, WA. I do not know if it will work on a 6. The senders are the standard aftermarket style with adapters. This is basically the surrogate gauge: http://store.summitracing.com/partdetail.asp?part=SUM-800111 If you can use this in your car, then the quad will work. I can do white faces as well. Mark |
JPB |
Nov 23 2006, 11:58 AM
How about nipper rods like Suby conversions? Very nice and a must have item.
pete-stevers |
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
looks great!!! wish you could put one togather for a six....
i would order in a flash.... perhaps instead of water temp- oil pressure just dreamin out loud..... |
IanStott |
Nov 23 2006, 12:10 PM
Member Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 |
I am very interested in this, will save to my file, when I start reassembly this is just what I want.
Ian Stott Moncton Canada |
jwalters |
Nov 23 2006, 12:11 PM
Do you mean oil temp vs water temp?? Can do both - |
marks914 |
Nov 23 2006, 12:15 PM
The gauge should work on most water cooled engines, no use for a water temp gauge on an air cooled car.
Mark I believe it should work on a subie, the senders have some metric adapters. If anyone has aftermarket gaues on their subie, then this one will work as well. Mark |
Air_Cooled_Nut |
Nov 23 2006, 12:23 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Looks good. For the e-brake indicator, how about a super-bright LED or two hidden off to the side of one of the gauges that is(are) illuminated when the brake is set.
boxstr |
Nov 23 2006, 12:32 PM
So is the pricing the same as the surrogate gauge set? (IMG:style_emoticons/default/biggrin.gif)
CCLINQUADTUPLETS |
marks914 |
Nov 23 2006, 12:37 PM
So is the pricing the same as the surrogate gauge set? (IMG:style_emoticons/default/biggrin.gif) CCLINQUADTUPLETS the surrogate gauge set is $67 I use the guts and senders from this set and the rest is fabbed. The quad gauge will be around $250 Mark |
jwalters |
Nov 23 2006, 12:41 PM
The gauge should work on most water cooled engines, no use for a water temp gauge on an air cooled car. Mark I believe it should work on a subie, the senders have some metric adapters. If anyone has aftermarket gaues on their subie, then this one will work as well. Mark The reason I said that is because all of our engines have the plate to add a temp sender for the oil - the water gauge uses the same resistance as the oil senders - it is good to keep an eye on oil temps. This tells you allot about what is going on inside an aircooled engine-- |
neo914-6 |
Nov 23 2006, 01:29 PM
(IMG:style_emoticons/default/clap56.gif) Nice work!
914-8 |
Nov 23 2006, 01:54 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Very nice! For a SBC, I assume?
I'd buy one for $250 or less! Would like to have the e-brake light, though. Would it be hard to put one in place? If not, I suppose I could run the e-brake light to somewhere else on the dash. I kinda need it, I'm not 100% at remembering to put the brake down! Very nice work! |
Lo-Fi Version | Time is now: 17th May 2024 - 08:20 PM |
