tarett bar, what size for street and X-cross |
Brad Roberts |
Nov 28 2006, 12:02 AM
Pete,
How you doing? Taking all this in?? I wouldnt run the larger bars with the Tarret (I speak from experience) this is fine for a road race car, but lets start a little softer on the t-bars. I suggest the Koni's on all 4 corners and at least the 175' s in the rear for your 9146. This will work very well for you at AutoX. You'll have just enough adjustability to keep you busy between rounds but not overwhelm you. When the track time comes around.. step up on the front bars and rear springs (225lb) B |
pete-stevers |
Dec 2 2006, 11:22 AM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
thanks Brad!
now where does one find some torsion bars....what vendors? and why konis over billys.. |
J P Stein |
Dec 2 2006, 11:51 AM
thanks Brad! now where does one find some torsion bars....what vendors? and why konis over billys.. I would stick with the stock SC T bars. Cheep, used. Put a WTB ad on pelican 911 parts. If you have Boge struts (most SCs were) go with Konis for the adjustability. If you have Bilstein struts, go with Bilstein (Sports are an option)...cause nuthin else fits.....simple, eh? |
pete-stevers |
Dec 3 2006, 03:34 PM
silly question.....koni inserts are available as inserts only and will fit the stock sc strut??
as opposed to buying the whole strut assembly with billies.... ..................................... now i am looking for some stock t bars....mine are all rusty and pitted ............................................. any opinion on the cross member... andy says go with steel....i have both steel and alum sitting |
J P Stein |
Dec 3 2006, 04:08 PM
silly question.....koni inserts are available as inserts only and will fit the stock sc strut?? as opposed to buying the whole strut assembly with billies.... ..................................... now i am looking for some stock t bars....mine are all rusty and pitted ............................................. any opinion on the cross member... andy says go with steel....i have both steel and alum sitting The Koni inserts will fit the Boge struts....Boge are black, Bilstein are green....or were back in SC days. The Aluminum is lighter and somehow the SCs/Carreras (which are 400+lbs heavier than 914s) got along with the supposed flex. If I had an Aluminum jobbie I'd put it in....but then, I'm trying to make weight. If you don't use it lemmeno & I'll buy it from you....if its cheep (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 7th May 2024 - 07:02 PM |
