Head Temperatures, Normal Range? |
BenNC |
Nov 12 2003, 01:11 PM
Member Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
I know that it has been posted before, but I can't find it.
What are typical cylinder head temperatures when measured using an under the plug type of sender? Thanks, |
cha914 |
Nov 12 2003, 01:30 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
I think 350 is about normal if I remember correctly...
Tony |
Jake Raby |
Nov 12 2003, 01:31 PM
325-365 is great......up to 400 climbing hills. Not over 425.
Rusty |
Nov 12 2003, 01:40 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
400 is cure temp for powder coating. That's gotta be hard on refinished cooling tin.
BenNC |
Nov 12 2003, 02:34 PM
Hmmm, I'm getting just a tick over 400 when I run at 70 (3200 - 3300) for 20-30 minutes. Drops back below 400 when speed drops.
Jake Raby |
Nov 12 2003, 03:50 PM
The engine is out of tune.......Timing is high or you are running lean.
My 180BHP 2316 won't go over 375 with stock cooling. |
BenNC |
Nov 13 2003, 01:34 PM
Thanks Jake,
After I check the timing, if it is OK or if the temps stay high after correcting how do I determine if I'm running lean? BTW: If you're just answering to throw out the phrase "180BHP 2316," then do it again. It sort of makes me feel warm all over. (IMG:style_emoticons/default/smile.gif) |
Jake Raby |
Nov 13 2003, 01:38 PM
LOL.
I was just answering that by saying I'm making 45 HP per cylinder and running cooler than that with a stock cooling system....... |
redshift |
Nov 13 2003, 02:11 PM
If you are lean, the engine may hunt at idle (FI? Carbs?) also, you would notice your head temps above normal..
Too much advance. I run a gear lower than you do at the same speed... I am betting you are over-advanced, if you leave it in 4th, what's the temps? Cooler? -edit Ben, have you checked that all of your fins, and the fan, and the tin aren't fouled by leaves or pooh of any kind? M |
Jake Raby |
Nov 13 2003, 02:58 PM
I don't use 5th till 80MPH..... 5th gear kills cylinder heads! not enough cooling fan/engine RPM and too much load for a stock engine!
Mueller |
Nov 13 2003, 03:15 PM
QUOTE I don't use 5th till 80MPH..... 5th gear kills cylinder heads! not enough cooling fan/engine RPM and too much load for a stock engine! very interesting.....any idea on how much HP is needed at certain MPH in the 914 or bugs?? also, when someone purchases an engine from you (lets say a stocker) do you give them the above advise on the use of 5th gear or about keeping the revs up to increase cooling? |
redshift |
Nov 13 2003, 03:16 PM
Yes.
Although I have been a wallet mechanic for all these years, I do know these things like to be driven hard. A motor lasts longer way @ 4000 than it does at 3000, and it's 100% more fun. (and with injection *JAKE* you can do it 3 times as long between gas pumps... (IMG:style_emoticons/default/laugh.gif) ) Keep up with traffic, it's not a sin! M |
Jake Raby |
Nov 13 2003, 03:43 PM
Over the weekend I went 12 hours one way on 1/2 tank of fuel! With carbs, thats 38MPG at 85MPH.
redshift |
Nov 13 2003, 03:51 PM
TheCabinetmaker |
Nov 13 2003, 04:02 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Uh, Jake. 12 hours @ 85mph is 1020 miles. That's more like 127 mpg on a stock tank. How big is your fuel tank?
Jake Raby |
Nov 13 2003, 04:18 PM
I wasn't driving the entire time! LOL
Half the time I was busy blasting by a 64 Ghia and letting him catch up.... |
TheCabinetmaker |
Nov 13 2003, 04:21 PM
Ok, I thought you might have stopped at a rest stop for a 9 hour nap (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 02:23 AM |
