Engine Rebuild Recommendations, ...economical more HP optons?? |
nebreitling |
Nov 27 2006, 10:16 PM
ain't nothin' magic: good port work, good cam, hi-compression, great exhaust, solid valve train!
Bleyseng |
Nov 27 2006, 10:33 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Budget 100hp? 1911 with djet or ljet is quite possible using Rat/Ham heads, 96's, 9550 cam and alittle tuning work.
ChrisFoley |
Nov 28 2006, 12:52 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I got a 1.7L up to about 140hp with a Web 86A (street) cam, hd single valve springs, reworked Weber 40IDFs, 1.8L heads with stock dia. stainless steel valves, and good port work. It wasn't too bad at low rpm and really came alive above 4K rpm. Oh yeah, and a Tangerine EVO Header! Hey, what would be your personal thoughts on the 86A ??? I like the balance of streetability and power from that cam. With just the cam, unmodified carbs and header the engine made a bit more power than stock. I never dynoed it but estimated the peak to be around 100hp. When I added the head work and opened up the carb inlets it rocked! The improvement was dramatic. Peak power was around 6200 rpm but didn't begin to drop off until close to redline (valve float) at 6800. I did have ceramic lifters too, which made the high redline possible. I chose the 86A because I could still use single valve springs and the increased lift and duration would provide big gains if I invested in better breathing. It was an easy combination to assemble. I ran it with stock heads for close to two years, then re-did the top end right before going to the Runoffs in '03. On a Dynojet I got 125 rwhp. I continued to race with that engine thru '04 and much of the '05 season as well. |
ChrisFoley |
Nov 28 2006, 12:59 AM
ain't nothin' magic: good port work, good cam, hi-compression, great exhaust, solid valve train! Exactly! Actually, I did the port work myself, so it could have been better. The valves were set up professionally with new guides and seats. IIRC the compression was around 10.5:1. I used domed (factory shape)Wiseco pistons and I did have to add pockets for the valves. |
Jake Raby |
Nov 28 2006, 10:01 AM
The 86A wakes up with split duration. I have a grind that is very similar to the 86A with a few dehrees more on the exhaust and a split center line..
straight pattern cams are so ineffective for the Type 4 that I don't even stock them any longer... |
Carlitos Way |
Nov 28 2006, 10:49 AM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
The 86A wakes up with split duration. I have a grind that is very similar to the 86A with a few dehrees more on the exhaust and a split center line.. straight pattern cams are so ineffective for the Type 4 that I don't even stock them any longer... Jake, for those unedumakated people like me, can you illustrate what you're talking about without releasing any proprietary information? Thanks |
anthony |
Nov 28 2006, 11:30 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
If you do a google search you'll find lots of tutorials on cams. This looks pretty good:
http://www.thirdgen.org/sbc-camshafts-primer |
sean_v8_914 |
Nov 28 2006, 01:34 PM
I built a 1.8 L-jet with 96mm pistons and Jakes cam. it was faster than my buddies 2.0 and ran great with the FI. I also did a 2.0 with 96mm and a Jake cam, a 2056 with D-jet. I think they are different p/n for D vs L jet FI cams. it was perky but requires a re-tune on teh MPS. I built both motors out of back yard parts. only had to buy the essensials like rings, bearings and gaskets.
either combo ws well worth the effort. both cars were sold. I have not heard back from the new owners. Just make sure you inspect carefully or get an experienced eye to look over your parts prior to assembly |
Jake Raby |
Nov 28 2006, 03:12 PM
Any cam enhancement will require an MPS tweak.. The 9550 was designed especially for D jet and it has great tuning characteristics due to the very graceful opening of the intake valve thats similar to stock from .40 lift all the way to past .400, thats not a characteristic of any other cam that you'll find.. The exhaust promotes better head efficiency and reduction in heat..
I have an L jet version of the 9550 as well, it's the 9550L and it was designed specifically for L jet with the same characteristics in mind. These are my two hottest selling cams! |
John |
Nov 28 2006, 04:15 PM
QUOTE with fresh heads from len and parts, probably around 1500-2000$ smile.gif I want to know how to get fresh heads from len, and enough new parts and machine work to build a quality engine that will last for this price range. When I priced out rebuilding my 2.0 (nearly stock) I was out of this budget range in short order. |
Jake Raby |
Nov 28 2006, 07:41 PM
You could have taken advantage of the 4th Dimension Radio specials. Len gave a hell of a price for labor for his heads as a product of the week and I also backed it up with a deal on valve train parts for those heads...
Bleyseng |
Nov 28 2006, 07:50 PM
The 2056 engine kit was something like $2900 too....on the Radio Special IIRC.
vesnyder |
Nov 28 2006, 08:13 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I want to bounce off everyone what I've learned and what my current plans are. I currently have SSI's along with a Bursch muffler - I will reuse these on my 1.8 rebuild. I will replace the P&C's with 96mm to create a 1911 cc. Any recommendations on manufacturer (AA, Mahle, KB?). I also plan on using Webers instead of FI along with Raby's cams (86A?).
Some questions: - What mods shold I do to the heads? - Should I look into a new crank to increase displacement? - What Webers should I look for - 40's? Keep in mind I am on a budget of ~$2k and want to maximize HP - at least 100! |
G e o r g e |
Nov 28 2006, 08:39 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
cam and lifters 275+ tax
bearings crank and cam and rods 62+ + tax heads 610(super stock ) + tax valve train 405 + tax P and C's 329+ tax sealants 75 or so gasket kit 75 crank shaft grind for stock 65 per Rimco rods recondition 15 each rimco case cleaning ?? Jakes rebuild video tin refurbish ??? plugs and wires?? Mallory ??? looks like 2k without carbs to me |
John |
Nov 28 2006, 10:16 PM
You could have taken advantage of the 4th Dimension Radio specials. Len gave a hell of a price for labor for his heads as a product of the week and I also backed it up with a deal on valve train parts for those heads... Unfortunately those "radio shows" came about a year too late..... This is an exerpt from when I had Len give me a quote: QUOTE The typical cost for a pair of 2.0 914 heads is in the neighborhood of $1100.00, parts and labor, including crack repairs of the common variety. Your heads will come with a 1 year unlimited mileage warranty. |
ChrisFoley |
Nov 28 2006, 10:40 PM
Some questions: - What mods shold I do to the heads? - Should I look into a new crank to increase displacement? - What Webers should I look for - 40's? Keep in mind I am on a budget of ~$2k and want to maximize HP - at least 100! The heads need new guides, stainless valves (stock dia is enough for more than 100hp) and heavy duty single springs, along with a little bit of port flow work ( a little bit goes a long way). You can keep the old valve seats if you don't mind a little risk. The combustion chambers should be cut to increase compression to about 9.5 to 1 (a preliminary guess). Get Jake's version of the 86A. 40IDF's or 40 Dells, 32mm main venturis. To stay close to budget I would leave the crank and rods alone if possible and keep the stock P&Cs. That will save you enough to get the carbs. I also think balancing the rotating assembly (fan, crank, flywheel, PP) is wise since you will need a rev limit of more than 6K rpm. The rods and pistons should be balanced as well. The long exhaust system, combined with the mass of the moving parts will limit the rpm and therefore the peak horsepower. The next step to more horsepower is lighter pistons, rods, lifters, etc. and a header. |
jd74914 |
Nov 28 2006, 10:51 PM
John, I'm seeing a total cost of about $2100 if you use new P/C's? You don't always have to replace evrything. IMHO, there's nothing wrong with reusing stuff like that if its within spec. The same with rod reconditioning and balancing, one can do that themselves.
Thats just MO, I feel confident rebuilding an engine using some of the stock VW parts, provided they look good. When I pulled my 1.8 apart nothing inside was abused and everything was measured within spec. |
vesnyder |
Nov 29 2006, 06:09 AM
I found a pair of Weber 40 IDE (are these different than IDF's?) carbs on eBay that came off a VW - will these fit? Can the venturis be changed?
Lo-Fi Version | Time is now: 1st June 2024 - 04:22 PM |
