Tie rod ends, when did they change? |
914werke |
Nov 28 2006, 02:03 PM
"I got blisters on me fingers" Group: Members Posts: 10,082 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Early to late the material and construction changed from a cast steel peice
to a bent steel bar with a section of threaded rod (IMG:style_emoticons/default/confused24.gif) When? Is there a reason other than manufacturing cost? this is posted here because the CW factor and becuase the likely response is "dump them and go turbo anyway" (IMG:style_emoticons/default/chairfall.gif) This is for a 74 application |
jd74914 |
Nov 28 2006, 07:14 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I would tend to believe that the bent steel rod is stringer than the cast piece. IDK if this has anything to do with the change though.
914werke |
Dec 2 2006, 11:50 PM
Lo-Fi Version | Time is now: 21st May 2024 - 01:41 AM |
