richardc197 |
Newbie ![]() Group: Members Posts: 3 Joined: 12-November 03 From: Rancho Santa Margarita, CA Member No.: 1,337 ![]() |
For the life of me I cannot figure out how to remove the passenger seat. I have been attempting to feel around under the set and around the seat rales for a tab, release or somthing. Help!
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
There is a spring tab in the seat track (not the one with the release). Look with a flashlight and you can see it. You can reach it with a screwdriver or your finger. Press it up while pulling the seat forward.
richardc197 |
QUOTE(jim9146 @ Nov 13 2003, 08:12 PM) There is a spring tab in the seat track (not the one with the release). Look with a flashlight and you can see it. You can reach it with a screwdriver or your finger. Press it up while pulling the seat forward. In the front or back? |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Front, opp side of the tab. where you think your fingers shouldnt go... press both the black pull tap and the spring tab that you press with your finger up and pull the seat at the same time.. Should slide right out.. but mine never does.
Andrew |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Pull the seat all the way forward first, then feel on the other seat rail for a piece of flat metal spring.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
after you pull the seat all the way forward then go back a little bit. this will let the spring push up easily. watch out when it releases and comes all the way forward. if you wear a glove you won't get a blood blister on your index finger.
kevin |
onrails |
if the world didn't suck,,we would all fall off ![]() ![]() Group: Members Posts: 118 Joined: 21-July 03 From: tulsa,ok Member No.: 929 ![]() |
blood blister! been there. (IMG:style_emoticons/default/headbang.gif)
(IMG:style_emoticons/default/agree.gif) yep,,,,,all the way forward,,& bacl just a-little! should pull right out.after pushing the tab. |
Lo-Fi Version | Time is now: 12th July 2025 - 06:29 AM |
