How do I get the seats out of my 75 914, I cannot find a tab on my seat rail. Hmm |
richardc197 |
Nov 13 2003, 10:02 PM
Newbie Group: Members Posts: 3 Joined: 12-November 03 From: Rancho Santa Margarita, CA Member No.: 1,337 |
For the life of me I cannot figure out how to remove the passenger seat. I have been attempting to feel around under the set and around the seat rales for a tab, release or somthing. Help!
Porsche Rescue |
Nov 13 2003, 10:12 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
There is a spring tab in the seat track (not the one with the release). Look with a flashlight and you can see it. You can reach it with a screwdriver or your finger. Press it up while pulling the seat forward.
richardc197 |
Nov 13 2003, 10:19 PM
QUOTE(jim9146 @ Nov 13 2003, 08:12 PM) There is a spring tab in the seat track (not the one with the release). Look with a flashlight and you can see it. You can reach it with a screwdriver or your finger. Press it up while pulling the seat forward. In the front or back? |
Andyrew |
Nov 13 2003, 11:09 PM
Front, opp side of the tab. where you think your fingers shouldnt go... press both the black pull tap and the spring tab that you press with your finger up and pull the seat at the same time.. Should slide right out.. but mine never does.
Andrew |
TheCabinetmaker |
Nov 14 2003, 06:50 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Pull the seat all the way forward first, then feel on the other seat rail for a piece of flat metal spring.
rhodyguy |
Nov 14 2003, 07:41 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
after you pull the seat all the way forward then go back a little bit. this will let the spring push up easily. watch out when it releases and comes all the way forward. if you wear a glove you won't get a blood blister on your index finger.
kevin |
onrails |
Nov 14 2003, 08:54 AM
if the world didn't suck,,we would all fall off Group: Members Posts: 118 Joined: 21-July 03 From: tulsa,ok Member No.: 929 |
blood blister! been there. (IMG:style_emoticons/default/headbang.gif)
(IMG:style_emoticons/default/agree.gif) yep,,,,,all the way forward,,& bacl just a-little! should pull right out.after pushing the tab. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:44 AM |
