Sweet Twin Blower, Wasserboxer case, VW drag car!, Will this fit in a 914? |
Britain Smith |
Dec 5 2006, 11:48 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Check out this engine build-up on the Austrailan VW site...
Aussie VW Forums (IMG:http://www.cbbvw.com/cranky_files/1409.jpg) Will this fit in a teener? -Britain |
VaccaRabite |
Dec 5 2006, 12:34 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Check out this engine build-up on the Austrailan VW site... Aussie VW Forums (IMG:http://www.cbbvw.com/cranky_files/1409.jpg) Will this fit in a teener? -Britain Sure. All you needs is a little (IMG:style_emoticons/default/sawzall-smiley.gif) and then some (IMG:style_emoticons/default/welder.gif) In like flynn. Zach |
Cap'n Krusty |
Dec 5 2006, 01:10 PM
That case doesn't even remotely resemble a wasserboxer case. The Cap'n
Boojum |
Dec 5 2006, 01:23 PM
Member Group: Members Posts: 95 Joined: 31-July 06 From: Denver, CO Member No.: 6,550 |
It says in the article that the water jackets were machined off to accommodate air cooled cylinders. If that's what you want to call them, they have no fins, so I don't know how effective that could possibly be. Presumably the wasserboxer case is stronger in some way?
Regardless, it's pretty crazy, but it looks like it does the job. |
Jake Raby |
Dec 5 2006, 01:31 PM
have done an "Oxyboxer" before... There is a lot of machining involved.
The wasser is a culmination of a TI and TIV engine with a few specialized parts. The biggest benefit of the wasser is that it uses TIV mains and a TIV flywheel attachment method and the fact that it has a die cast aluminum case made of the same material as the TIV and 911 cases. The one I id was built from 100% VW parts with the only aftermarket part being the camshaft. It made 175HP from 2109cc.. Its one of the things I explored doing heavily before I decided to go wild with Type 4 stuff as a specialty, but there is so much machine work involved that it wasn't persued on my behalf.. And it uses a lot of Type 1 parts that are pure shit and made in 3rd world countries with a total lack of quality.. |
Cap'n Krusty |
Dec 5 2006, 01:36 PM
One would think a Scat case, or some of the others available to the drag racing market, would be a more cost effective solution. Not being a T1 guy, or a drag racer, that is pure speculation on my part. The Cap'n
Lo-Fi Version | Time is now: 15th May 2024 - 11:10 AM |
