Spray gun for applying por15 |
sj914 |
Nov 14 2003, 08:40 AM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Mark Henry |
Nov 14 2003, 09:40 AM
Phone Por-15, they will tell you if an airless would work.
With the shipping the price of that one it's not too far off how much they are at Home Debit. If it's just the regular por-15 the stuff flows real good with just a brush, when it's done it looks like you used an airgun. Also be real careful with overspray! It sticks to everthing and will not come off!!! |
Qarl |
Nov 14 2003, 09:58 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
If you spray, you need to get their special thinner. It's too thick to spray as is.
I used a small HVLP spray gun. GOOF OFF removes POR-15 very well while still wet. Great for cleaning out your paint gun!!! |
TheCabinetmaker |
Nov 14 2003, 10:01 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Don't waste your money. That's a knock off of the Wagner power painter. The spray pattern is round, not flat. Might be good for painting a fence, but everything else will run, run, run. It won't atomize the paint without thinning it to the point of being like water.
sj914 |
Nov 14 2003, 10:06 AM
I guess I'll be breaking out the HVLP I've got. I just didn't want to use my real spray gun for por-15.
TheCabinetmaker |
Nov 14 2003, 10:08 AM
Use the HVLP gun. It'll work great. Just clean it good immediately.
Qarl |
Nov 14 2003, 10:16 AM
Run goof off through it to clean it... it dissolves it instantly!!!
rezron |
Nov 14 2003, 12:47 PM
Member Group: Members Posts: 327 Joined: 25-December 02 From: Mason City, Iowa Member No.: 10 |
I just used one of my smaller touch up guns that I use for doing jambs. It's just a siphon gun- not hvlp. It worked fine
shooting it straight out of the can with no thinning. rezron |
Rusty |
Nov 16 2003, 12:09 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Sorry I'm chiming in late. Don't run POR-15 through your good HVLP gun.
Get an el-cheapo Harbor Freight touch up gun, use it and throw it away. The advice you got about thinning POR-15 is correct. You'll need their thinner. IIRC, the mix is 10:1. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Mueller |
Nov 16 2003, 12:37 PM
use a strainer with the paint to help remove any solids that might be in it....I agree with Lawrance, just get a cheap "detail" sprayer so that if you toss it, you'll only be out a few bucks.
Joe Ricard |
Nov 16 2003, 05:51 PM
Don't let it dry on your hands. Read label 1st. Don't get it on your hands, If you do stop what you are doing and clean up. Don't get it on your hands. I wore this stuff for like three days I guess I will never rust. at least on my hands. (IMG:style_emoticons/default/chair.gif)
sj914 |
Nov 16 2003, 07:17 PM
Thanks for all the advise. Ruining my spray gun is what I want to avoid. Now this is alittle OT from spray guns, but there is some obvious places I cant sand or grind the rust out of ex. cable shield for the e-brake line. Is getting all the rust off that critical?
Lo-Fi Version | Time is now: 31st May 2024 - 06:37 AM |
