Where the pan meets the longitudinal..., ...waddaya think? |
1970 Neun vierzehn |
Dec 9 2006, 01:11 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Now I'm getting uneasy....the shop sez the longs are fine, I'm getting feedback from folks whose opinion I value that they're bad. Obviously the pan is rotted, but where does the one end , and the other start? I colored the long "orange" to highlight it from the rusted pan.
Dec 9 2006, 02:10 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
everything *between* the yellow lines is the bottom of your long !!!!
everything inside the red lines shows the bottom of the hell hole ... everything inside the green lines is your floorpan ... like i said before, that round tube you see is the metal part of the heater tube that runs inside the long (IMG:style_emoticons/default/ohmy.gif) if the longs were OK, you shouldn't be able to see inside ... makes sense? (IMG:style_emoticons/default/cool_shades.gif) Andy PS: this *is* fixable, but it's not an easy repair. you will HAVE TO support the chassis correctly to keep it within specs before you weld this up. your chassis is already flexing and out of spec as it is. the two longs are the spine that holds your car together. if one is weakend like that, your car *is* flexing ... Attached image(s) |
Dec 9 2006, 02:20 PM
the longs are rectangular boxes of metal. and i your case, at least the bottom part of the box is rotted away, maybe even more. (can't tell from just that one picture) ...
(IMG:style_emoticons/default/welder.gif) Andy |
Pat Garvey |
Dec 9 2006, 06:23 PM
I think Andy's right - you shouldn't be able to see that tube. Better check with the guys @ Stoddard. Not a good sight.
Ferg |
Dec 9 2006, 09:41 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Andy, thanks for the Photoshop skills, Glad we are now all on the same page.
Andy's right. Needs to be braced before welding. I'm only speaking from the outside and only based on what i've read here, but i'm doubting the knowledge of the shop doing the resto. Last thing I want to see is someone drop a boatload of $$ on a resto, that's not done correctly. Andy, and other's know much more than me, but HERE is the place to get the info to cross check against the work being done. Just my 2 cents. Ferg (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 30th April 2024 - 01:13 AM |
